[GRASS-user] Pre-processing LANDSAT TM Orthorectified images from GLCF
For a project I am involved with, we are conducting landcover
classification from LANDSAT TM (orthorectified) data downloaded from
GLCF.
We are now in the process on pre-processing the image and then conduct
classification using i.smap.
Following the GRASS book, we will be conducting the pre-processing
steps outlined:
1. calibration from DN to apparent radiance at sensor - gain/bias offsets
following grass book 2nd ed. (page 222)
r.mapcalc "band.rad = ((LMAX - (LMIN))/(255.0 - 1.0)) * (band -1.0) + (LMIN)"
or
i.landsat.toar
2. correction for atmospheric effects
use i.atcorr
problem: the metadata supplied by GLCF does not indicate image acquisition time
sample metadata: http://tinyurl.com/6oo428
or use
i.landsat.dehaze
3. correction for topographic/terrain effects (most of my study area
are in maountainous regions)
use book 2nd ed. (page 226) "cosine correction"
using r.sunmask, r.mapcalc
Problem: again, no image acquisition time
4. removal of clouds
use i.landsat.acca
https://svn.osgeo.org/grass/grass-addons/imagery/i.landsat.acca/
The beauty with GRASS and the GRASS book is that it has the
tools/modules I need for this project, however, I find it difficult to
choose which one I should use (i.atcoor or i.landsat.dahaze?). Am I
following the steps in correct order? Or is it necessary to do all
this? Reading from GLCF documentation, they did orthrectification for
this image already.
Any pointers would be very helpful.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
On Mon, Jun 2, 2008 at 7:50 AM, maning sambale
<emmanuel.sambale@gmail.com> wrote:
classification from LANDSAT TM (orthorectified) data downloaded from GLCF.
steps outlined:
or
i.landsat.toar
i.landsat.toar is the more sophisticated approach (or, easier since you
don't need to write the formula manuallly).
use i.atcorr
or use
i.landsat.dehaze
AFAIK LANDSAT is sun-synchronous, it passes in the local morning time
(something like 10:30-11:00).
Maybe this helps:
http://earthobservatory.nasa.gov/MissionControl/overpass.html
i.atcorr is the sophisticated correction, i.landsat.dehaze only a simple
approach based on image statistics.
(see above). "cosine correction" is a simple approach. See also
i.topo.corr (from GRASS AddOns).
use i.landsat.acca
Never tried, please report back.
this image already.
I have collected all this now in
http://grass.osgeo.org/wiki/Image_processing#Preprocessing
Feel free to further improve that Wiki page.
Markus,
Maybe this helps:
Since it is an overpass predictor, it doesn't provide information on
previous landsat overpass. Can I use this as a proxy to the hh:mm for
i.atcorr (me thinks no)? Or set an arbitrary time say between 10:30
to 11:00?
Thank you for this one.
use i.landsat.acca
Will do, via wiki.
As usual, thank you very much.
cheers,
maning
| _)_/LI
I have created a simple script to automate the pre-processing process
of landsat tm+. Here it is, if you see it needs improvement (my bash
skill is very rudimentary) please comment:
#!/bin/sh -x
# Script to automate pre-processing of LANDSAT ETM+ data
# Requires bands 1-5, 6 & 7 from
ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2 and also a DEM file
# Requires i.landsat.toar, i.topo.corr, i.landsat.acca module from grass addons
# June 12, 2008
# set the following variables
#original band prefix
BANDPREF=lsat7_2000
#path to metadata
METADATA=/home/maning/pfua/map_data/landsat/glcf_met/p111r054_7x20000309.met
#data of image
DATE=2000-03-09
#solar elevation
SUNELV=57.1772505
#sun zenith you can get it from http://www.nrel.gov/midc/solpos/solpos.html
SUNZEN=32.727
#sun azimuth
SUNAZI=112.3801002
#dem file
DEM=dem_90
############## nothing to change below
if [ -z "$GISBASE" ]
then
  echo ""
  echo "You must be in GRASS GIS to run this program"
  echo ""
  exit 1
fi
g.region rast=${BANDPREF}.1
# calibrate DN values to top of atmosphere radiance
echo "Calibrating to radiance ..."
i.landsat.toar -7 -v band_prefix=${BANDPREF} metfile=${METADATA}
echo "Imported as '${BANDPREF}.toar.bandnumber'"
echo "Correcting topographic effects ..."
i.topo.corr -i base=${DEM} zenith=${SUNZEN} azimuth=${SUNAZI} out=cosi
i.topo.corr base=cosi
input=${BANDPREF}.toar.1,${BANDPREF}.toar.2,${BANDPREF}.toar.3,${BANDPREF}.toar.4,${BANDPREF}.toar.5,${BANDPREF}.toar.61,${BANDPREF}.toar.7
out=tcor zenith=${SUNZEN} method=c-factor
echo "Calculating cloud cover ..."
i.landsat.acca -f2s band=tcor.${BANDPREF}.toar out=${BANDPREF}.acca
echo "Done!"
g.list rast
Some notes:
1. Calculation for solar zenith is taken from:
2. DEM for i.topo.corr is the default SRTM resolution (90m), is this okay?
3. i.landsat.cca gives very good results, however, adding the -s flag
(for cloud shadows), sometimes misclassify water bodies such as
rivers.
image: http://farm4.static.flickr.com/3126/2571893895_0a73dd3380.jpg
cheers,
maning
On 6/2/08, maning sambale <emmanuel.sambale@gmail.com> wrote:
Markus,
Maybe this helps:
to 11:00?
use i.landsat.acca
Will do, via wiki.
cheers,
maning
