[GRASS-user] Preprocessing irsp6 liss4
Dear Neil/Srini,
I'd like to be able to use a single set of training sites for about 6 adjacent imageries (IRS P-6 LISS-IV).
I've pre-processed the imageries, calculating the apparent radiance at sensor using the gain and bias values provided in the header (attached file). I had somehow thought this would fix the problem but results show that I still need to re-calibrate the imageries by regressing the images using values for same/similar object pairs (water bodies, field etc.).
Is this the correct procedure?
Header file used for gain/bias(offset) and screenshot of results attached.
Ravi
(attachments)
gdalinfo.txt (6.26 KB)
you posted to a list... perhas you need to perform atmospheric
correction (i.atcorr in GRASS) since they might come from different
acquisition dates?
Best,
On Thu, Jul 30, 2009 at 3:44 AM, Ravinder Singh
Bhalla<rsbhalla@gmail.com> wrote:
Dear Neil/Srini,
Ravi
Driver: GTiff/GeoTIFF
Files: BAND2.TIF
Size is 6076, 6232
Coordinate System is:
PROJCS["GeoTIFF Version 1.8.1 October 31, 1995,
http://www.earthlink.net/~ritter/geotiff/geotiff.htm&quot;,
GEOGCS["Indian 1975",
DATUM["Indian_1975",
SPHEROID["Everest 1830 (1937
Adjustment)",6377276.345,300.8016980102425,
AUTHORITY["EPSG","7015"]],
AUTHORITY["EPSG","6240"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4240"]],
PROJECTION["Polyconic"],
PARAMETER["latitude_of_origin",12.159814569919],
PARAMETER["central_meridian",79.5816375647949],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-15215.028340350654616,15587.608734479999839)
Pixel Size = (5.000000000000000,-5.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_IMAGEDESCRIPTION=PRODUCT ID =08003005-01 LOCATION =101/14300
ACQUISITION DATE =20061204
SATELLITE =IRS P6 SENSOR =LISS4 SENSOR MODE =PLD MX LOOK ANGLE =
-8.25
LOCATION = ACQUISITION DATE =
SATELLITE = SENSOR = SENSOR MODE = LOOK ANGLE =
PRODUCT TYPE =MAP ORIENTED PRODUCT SIZE =FULL SCENE
TYPE OF PROCESSING =SYSTEMATIC RESAMPLING =CC
VOLUME #/# IN SET =01/01 PIXELS PER LINE = 6076 LINES PER BAND = 6232/ 6232
START LINE # = 1 BLOCKING FACTOR = 1 RECORD LENGTH = 6076 PIXEL SIZE =
5.00
OUTPUT BITS PER PIXEL = 8 ACQUIRED BITS PER PIXEL = 7
BANDS PRESENT =234 PRODUCT CODE =STPC00GTJ
VERSION NO =IRSP6DPSV1R2 ACQUISITION TIME =05:11:24:523
GENERATING COUNTRY =INDIA GENERATING AGENCY =ISRO/NRSA
GENERATING FACILITY =DPS-5 PRODUCT ENDIAN =LITTLE
REV CBIASES AND GAINS IN THE BAND ORDER AS ON THIS TAPE
0.000000000000000 27.165099999999999
0.000000000000000 23.056600000000000
0.000000000000000 36.777299999999997
0.000000000000000 0.000000000000000
SENSOR GAIN STATE = 2 2 1
SENSOR STATE =GOOD
GEOMETRIC DATA MAP PROJECTION =POL ELLIPSOID =EVEREST DATUM
=IND-I
USGS PROJECTION PARAMETERS = 6377276.345000000670552
6356075.412999999709427
0.000000000000000 0.000000000000000 79.581637564794903
12.159814569919002 0.000000000000000 0.000000000000000
0.000000000000000 0.000000000000000 0.000000000000000
0.000000000000000
UL = 0792630.2977E 121802.5057N -15215.028 15587.609
UR = 0794315.8359E 121802.5065N 15164.972 15587.609
LR = 0794315.3078E 120108.3931N 15164.972 -15572.391
LL = 0792630.8276E 120108.3922N -15215.028 -15572.391
CENTER = 0793453.0673E 120935.5788N -25.028 7.609 3038 3116
OFFSET = 5 ORIENTATION ANGLE = 0.00
SUN ELEVATION ANGLE =67.3 SUN AZIMUTH ANGLE = 96.7 ALTITUDE =821421.00000
HEADING ANGLE = 192.968399
TIFFTAG_SOFTWARE=
TIFFTAG_DATETIME=2008:02:22 16:30:24
TIFFTAG_ARTIST=Sk. Sazid Mahammad,DPSD/SIPG/SIIPA, SAC,
ISRO,Ahmedabad-53,India., e-mail:
TIFFTAG_HOSTCOMPUTER=DPS-5
TIFFTAG_XRESOLUTION=0.0020000001
TIFFTAG_YRESOLUTION=0.0020000001
TIFFTAG_MINSAMPLEVALUE=0
TIFFTAG_MAXSAMPLEVALUE=255
TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -15215.028, 15587.609) ( 79d26'30.30"E, 12d18'2.51"N)
Lower Left ( -15215.028, -15572.391) ( 79d26'30.83"E, 12d 1'8.39"N)
Upper Right ( 15164.972, 15587.609) ( 79d43'15.84"E, 12d18'2.51"N)
Lower Right ( 15164.972, -15572.391) ( 79d43'15.31"E, 12d 1'8.39"N)
Center ( -25.0283404, 7.6087345) ( 79d34'53.07"E, 12d 9'35.58"N)
Band 1 Block=6076x1 Type=Byte, ColorInterp=Gray
grass-user mailing list
grass-user@lists.osgeo.org
