[GRASS-user] Problem accessing GRASS from GRASS from PostgreSQL9.1/PostGIS2.0 via pg-python or plpythonu
Thanks Andrew
I suggest running a test script that reports sys.path to confirm that the actual Python module search path seen by the Postgres server's environment is as expected.
From the python console, logged in as posgres user....
postgres@ip-10-252-74-140:/home/ubuntu$ python -c 'import sys; print sys.version, sys.path'
2.7.3 (default, Apr 20 2012, 22:39:59)
[GCC 4.6.3] ['', '/home/ubuntu', '/usr/local/grass-6.4.3svn/etc/python', '/usr/local/grass-6.4.3svn/etc/python/grass', '/usr/local/grass-6.4.3svn/etc/python/grass/script', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
From postgresql....
test=# CREATE FUNCTION pyversion() RETURNS text AS $$
test$# import sys
test$# return sys.version + '\n' + '\n'.join(sys.path)
test$# $$ LANGUAGE plpythonu;
CREATE FUNCTION
test=# select pyversion();
                      pyversion
2.7.3 (default, Apr 20 2012, 23:04:22) +
[GCC 4.6.3] +
/usr/lib/python2.7 +
/usr/lib/python2.7/plat-linux2 +
/usr/lib/python2.7/lib-tk +
/usr/lib/python2.7/lib-old +
/usr/lib/python2.7/lib-dynload +
/usr/local/lib/python2.7/dist-packages +
/usr/lib/python2.7/dist-packages +
/usr/lib/pymodules/python2.7 +
(1 row)
test=# CREATE OR REPLACE FUNCTION pgpython_test()
test-# RETURNS text LANGUAGE python AS
test-# $python$
test$# import sys
test$# def main():
test$# $python$;
CREATE FUNCTION
test=# select pgpython_test();
              pgpython_test
3.2.3 (default, May 3 2012, 15:48:36) +
[GCC 4.6.3] +
/usr/lib/python3.2 +
/usr/lib/python3.2/plat-linux2 +
/usr/lib/python3.2/lib-dynload +
/usr/local/lib/python3.2/dist-packages +
/usr/lib/python3/dist-packages
(1 row)
OK, I've got two versions of python: 2.7 and 3.2...
Both python console and postgresql can see python 2.7 but plus it appears the grass environmental variables are not finding their way into the $pythonpath as seen by the postgresql server???
Any suggestions?
