[GRASS-user] problem addon v.in.ply with grass 7 on ubuntu 14.04
dear all,
someone know why the addon v.in.ply does not work on ubuntu 14.04 with Grass 7 stable but works well in windows 7?
I tested it with a file of 90 MB.
There is a specific procedure to install the addon v.in.ply, v.rectify and v.out.ply under ubuntu?
I followed this procedure (http://arc-team-open-research.blogspot.it/2013/12/from-drone-aerial-pictures-to-dem-and.html).
I can send you the file if someone wants to test it.
thanks
Dr. Nat. Carmine Massarelli, Ph.D.
National Research Council
On Thu, May 28, 2015 at 12:12 PM, Carmine Massarelli
<carmine.massarelli@ba.irsa.cnr.it> wrote:
dear all,
What is exactly the problem? Is installation failing or the script fails?
Please post the error message.
Best
http://consulting.neteler.org
http://courses.neteler.org/blog
http://gis.cri.fmach.it/neteler/
Dear Markus,
I left the PC working (workstation 32GB) in elaboration for all the nightwithout results and without receiving any errormessages.
On the Windows machine (4 GB) complete processing took about 8 hours.
I just remember that I had trouble installing the addon on grass maybe due topermissions, therefore i wonder if there is a special procedure for the installation.
Carmine
dear all,
Best
Research fellow
Water Research Institute (IRSA)
Addr: De Blasio n.5 - 70132 Bari Z.I.
Tel: +39 080 582 05 06
Dear Carmine,
On Fri, May 29, 2015 at 2:49 PM, Carmine Massarelli
Dear Markus,
installation.
With Ubuntu you have have to use the -s flag for g.extension. But
since you installed it I don't know what to suggest. Maybe you can
make the file available and I can try on my Linux box (Fedora).
Dear Carmine,
Dear Markus,
I just tried with the file which I got offlist from you:
GRASS 7.0.1svn (nc_spm_08_grass7):~ > g.extension v.in.ply
Fetching <v.in.ply> from GRASS-Addons SVN repository (be patient)...
Compiling...
Installing...
Updating addons metadata file...
Installation of <v.in.ply> successfully finished
GRASS 7.0.1svn (nc_spm_08_grass7):~ > time -p v.in.ply
input=Downloads/pmvs_options.ply output=pmvs_options
Importing 1338857 vertices ...
Building topology for vector map <pmvs_options@neteler>...
Number of primitives: 1338857
Number of points: 1338857
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.in.ply complete.
real 60.93
user 47.52
sys 19.30
==> something like 1 minutes on my Fedora 21 box.
GRASS 7.0.1svn (nc_spm_08_grass7):~ > v.info -t pmvs_options
nodes=0
points=1338857
lines=0
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
volumes=0
holes=0
primitives=1338857
map3d=1
Lots of points... looks all good to me.
installation.
On Ubuntu you may need to install addons with the -s flag of g.extension.
Hope this helps,
Hello,
if i use g.extension -s extension=v.in.ply i receive the error
D2/5: filename = /usr/lib/grass70/scripts/g.extension
D1/5: G_set_program_name(): g.extension
D2/5: G_file_name(): path =
/media/massarelli/sdb/Mappe/GRASS/Statte/PERMANENT
D1/5: G_set_program_name(): g.gisenv
D2/5: G_option_to_separator(): key = separator → sep = ’
D1/5: grass.script.core.start_command(): g.version -rge
D1/5: G_set_program_name(): g.version
D1/5: grass.script.core.start_command(): g.message -e
message=Unable to create ‘/usr/lib/grass70/docs/rest’:
[Errno 13] Permission denied: ‘/usr/lib/grass70/docs/rest’
D1/5: G_set_program_name(): g.message
ERROR: Unable to create ‘/usr/lib/grass70/docs/rest’: [Errno 13] Permission denied: ‘/usr/lib/grass70/docs/rest’
(Fri Jun 5 16:03:55 2015) Comando terminato (0 sec)
According to you where is the permission problem (rest folder)?
Thanks
Il 06/05/2015 03:55 PM, Markus Neteler ha scritto:
Dear Carmine,
[<carmine.massarelli@ba.irsa.cnr.it>](mailto:carmine.massarelli@ba.irsa.cnr.it) wrote:
Dear Markus,
Compiling...
Installing...
Number of lines: 0
Number of areas: 0
Number of isles: 0
v.in.ply complete.
real 60.93
user 47.52
sys 19.30
nodes=0
points=1338857
lines=0
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
volumes=0
holes=0
primitives=1338857
map3d=1
installation.
Hope this helps,
Skype: carmine.massarelli
On Fri, Jun 5, 2015 at 4:05 PM, Carmine Massarelli
Hello,
message=Unable to create '/usr/lib/grass70/docs/rest':
[Errno 13] Permission denied: '/usr/lib/grass70/docs/rest'
ERROR: Unable to create '/usr/lib/grass70/docs/rest': [Errno 13] Permission
I think that the "rest" directory should not be generated at all.
Looks like a bug to me (strange that nobody else reported it so far AFAIK).
The workaround is to generate it manually now but I would prefer to
get the issue solved.
