Hi Folks,
I finally installed OS X 10.7.1. Because I had a corruption with Java I did a clean install. I’ve been gradually loading things back in. I ran into trouble when I got to GRASS. I have William Kyngebure’s 6.4.1-5. I launched it for the first time and got the following in Terminal:
/ / __ / | / / / / __/ / /
/ / __/ // / /| | _ \ \ / / __ / / _
/ // / , / ___ |/ // / / // // / / /
_// |// |/// _///_/
Welcome to GRASS 6.4.1 (2011)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4.1 (NH-State_Plane):~ > ERROR: MAPSET PERMANENT - permission denied
2011-09-10 18:49:22.524 Python[1232:e0f] CFURLCreateWithString was passed this invalid URL string: ‘/System/Library/CoreServices/CommonCocoaPanels.bundle’ (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
GRASS 6.4.1 (NH-State_Plane):~ > exit
exit
/Applications/GRASS-6.4.app/Contents/MacOS/etc/Init.sh: line 899: 1232 Killed: 9 “$GRASS_PYTHON” “$GISBASE/etc/wxpython/wxgui.py”
Closing monitors …
Closing open gis.m sessions…
Cleaning up temporary files …
Done.
Goodbye from GRASS GIS
logout
[Process completed]
‘/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh’; exit
Last login: Sat Sep 10 18:48:20 on ttys000
kurt-springss-mac-pro:~ kurtsprings$ ‘/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh’; exit
Rebuilding Addon HTML manual pages index…
Rebuilding Addon menu…
2011-09-10 19:01:52.382 osascript[1570:707] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
osascript: OpenScripting.framework - scripting addition “/Library/ScriptingAdditions/Adobe Unit Types.osax” declares no loadable handlers.
Python 2.6.6 found.
Starting GRASS …
2011-09-10 19:01:56.428 Python[1602:e0f] CFURLCreateWithString was passed this invalid URL string: ‘/System/Library/CoreServices/CommonCocoaPanels.bundle’ (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
I’ve loaded the frame works. Permissions were an issue as I moved things From time machine to a User with an (old) tag and ported them to my new user file. I think that was solved. Everything I’ve checked gives my new User Read and Write permission.
Any thoughts.
Kurt
