[GRASS-user] Problem after Installing OS X 10.7
Kurt wrote:
Permissions were an issue as I moved things From time machine
to a User with an (old) tag and ported them to my new user
file. I think that was solved. Everything I’ve checked
gives my new User Read and Write permission.
general advice: make sure that the user acc't who is opening the
mapset owns that mapset too, read+write permissions aren't enough.
this shouldn't stop you from reading @other_mapset from other
users sharing the same location though, and is probably not
responsible for your startup errors.
Hamish
