Hi folks
I have a small problem. I am running GRASS 6.3 on OS X 10.5.5. When I started with these maps I was use GRASS 5.0.2. As things evolved I converted them over. Now one map set is giving me grief. My sites and some vectors haven't been displaying on this map. I tried reconverting my sites to point vectors and got:
v.in.sites input=wedge_tombs.labled@PERMANENT output=wedgetomb8
Default database is not set
Input format: dimension: 2 strings: 1 FP:0
One problem vector area gave this:
v.convert input=map8_lake@PERMANENT output=Lake8 endian=big --overwrite --quiet
Vector map <Lake8> already exists and will be overwritten
All my other maps are fine. There were points when I was trying to attach a database to the maps, without success. So, I am not sure if I did anything inadvertently or not. I just want to fix these so they work again.
Also, if this will help diagnose the problem, the point vector file in the misbehaving map set have the following files:
coor
head
hist
While the ones that are working have:
cidx
coor
dbln
head
hist
topo
I am planning to use these maps in my ph.d dissertation, and wold like all of them working.
Can anyone tell me what is happening and more importantly how to fix it.
Kurt D Springs
