[GRASS-user] problem creating point layer from CSV file
Hello,
I tried to create a point vector from a table with coordinates:
db.in.ogr dsn=points_in.csv output=points key=myid
v.in.db --overwrite table=points x=UTM_E y=UTM_N key=myid output=points_vect
=> ERROR: x/y/z column must be integer or double
Why do I get this error?
How to I change the table column format for an imported ascii (CSV) table in order to match integer or double?
Thanks for your help.
Kind regards,
Timmie
To set the column type in db.in.ogr for a csv file, you have to create another file (e.g. points_in.csvt) with the column types.
See:
g.manual db.in.ogr
or
http://www.gdal.org/ogr/drv_csv.html
Alternatively, load the csv file with v.in.ascii, which will give you a chance to describe the column types.
Later
John
Tim Michelsen wrote:
Hello,
Kind regards,
Timmie
grass-user mailing list
grass-user@lists.osgeo.org
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
