[GRASS-user] Problem displaying imported 3D points shapefile in GRASS 7
I'm unable to display an imported 3D points shapefile in GRASS 7 svn (code
ver 57592). Importing with v.in.ogr proceeds without trouble, but on
selecting the imported layer to display, the system freezes until the
d.vect process is terminated.
I don't have this problem with GRASS 6.4.3, and the file displays in
OpenJump.
The file:
http://sedac.ciesin.columbia.edu/downloads/data/grand-v1/grand-v1-dams-rev01/dams-rev01-global-shp.zip
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-displaying-imported-3D-points-shapefile-in-GRASS-7-tp5076193.html
A clipped version of the file displays as lines after importing into GRASS.
See attachment.
<http://osgeo-org.1560.x6.nabble.com/file/n5076225/grass_point_shapefile.png&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-displaying-imported-3D-points-shapefile-in-GRASS-7-tp5076193p5076225.html
2013/9/5 RichardC <richtcooper@hotmail.com>:
what says `v.info`? Martin
(Thu Sep 5 19:54:21 2013)
v.info map=GRanD_dams_v1_1_epsg32647@PERMANENT
| Mapset: PERMANENT
| Database: /home/user/grassdata70 |
| Title:
| Map scale: 1:1
| Name of creator: user |
| Organization:
| Source date: Thu Sep 5 19:42:35 2013
| Timestamp (first layer): none
| Map format: native
| Type of map: vector (level: 2)
| Number of points: 19 Number of centroids: 0
| Number of lines: 0 Number of boundaries: 0
| Number of areas: 0 Number of islands: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: UTM (zone 47)
| N: 2119223.24607339 S: 1461884.90043981
| E: 805865.37994742 W: 456553.38018552
| Digitization threshold: 0
| Comment:
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-displaying-imported-3D-points-shapefile-in-GRASS-7-tp5076193p5076229.html
Perhaps related to this issue:
https://trac.osgeo.org/grass/ticket/2056#comment:1
My system:
Mint Linux 13(Ubuntu Precise)
32 bit
Display: GUI GRASS GIS Map Display
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-displaying-imported-3D-points-shapefile-in-GRASS-7-tp5076193p5076354.html
This appears resolved after upgrading to latest svn version.
see https://trac.osgeo.org/grass/ticket/2056#comment:4
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-displaying-imported-3D-points-shapefile-in-GRASS-7-tp5076193p5078198.html
just for the record:
grass70 -c GRanD_dams_v1_1.shp ~/grassdata/dams/
v.in.ogr GRanD_dams_v1_1.shp out=dams
g.gui
just displays nicely (again) the vector points.
