[GRASS-user] Problem grass-6.4.0 error setting region: child process exited abnormally
Could you please let us know the platform you are running on and where your copy of GRASS came from (compiled yourself, binary from someone else)?
Michael
On Sep 29, 2008, at 2:16 PM, <grass-user-request@lists.osgeo.org> wrote:
Date: Tue, 30 Sep 2008 01:15:21 +0400
Subject: [GRASS-user] Problem grass-6.4.0 error setting region: child
To: GRASS User <grass-user@lists.osgeo.org>
Message-ID: <097740D8-D779-43B8-869E-6A81FE4EE992@mac.com>
Content-Type: text/plain; charset="us-ascii"
         I'm getting some errors when trying to use some basic
grass-6.4.0 operations.
I click on Add a Raster Layer and select the aspect file from the
spearfish60 permanent dataset.
After that I click on Display Active Layers and I get an error message
"Error setting region: child process exited abnormally"
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic.png
After that I get an error message saying" Error can't read
parts(projection)": no such variable
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic-0001.png
If I click on the details button, I get the following error information:
can't read "parts(projection)": no such variable
    while executing
"regexp -nocase {^([0-9]+)} $parts(projection) trash parts(projection)"
    (procedure "MapCanvas::runprograms" line 46)
    invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
    (procedure "MapCanvas::drawmap" line 38)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
What could be causing it? I just built grass-6.4.0 on Mac OS X 10.5.5.
Best regards,
Elvis Dowson
