I am having a problem with GRASS on OS 10.5.8. When I launch a project, GRASS freezes when I resize the Map window by dragging the corner (which I have done in the past) it freezes. I can resize using the green resize but on the window (the one next to the red close window button and the amber put window in dock button) and it works fine. But the moment I try to resize by using the corner, it refreshes a few times but freezes. I can’t access menus or scroll. Interesting point, in the GIS Manager window, the Map Layers for Display 1 portion of the window runs into the bottom portion were the layer is chosen and set up. You can see the layer icon and the check box, but not the text describing the layer. It is like this before it freezes.
As a point of interest, I have installed Snow leopard on my lap top. GRASS froze when I tried to resize it first, but when I opened my map file first, populating the Map Layers, it worked fine. I did get an error code when I started up:
Last login: Fri Sep 11 10:38:37 on ttys000
kurt-springss-macbook-pro:~ kurtsprings2$ ‘/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh’; exit
Rebuilding Addon HTML manual pages index…
Rebuilding Addon menu…
2009-09-11 11:12:11.503 osascript[633:903] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
osascript: OpenScripting.framework - scripting addition “/Library/ScriptingAdditions/Adobe Unit Types.osax” declares no loadable handlers.
Warning: No Python 2.5 found, needed by wxPython.
The wxPython GUI may not work properly.
Cleaning up temporary files …
This was from my lap top running 10.6.1.
What I really need is a fix for my desk top running the older Leopard. Any thoughts?
Kurt Springs
