[GRASS-user] problem importing narr data into GRASS
Good morning. I’m trying to layer on some NARR (North American Regional Reanalysis) data onto my location but am having some issues. When I go to import the data (r.in.gdal -o -e input=/d1/grassdata/narr_data/narr-a_221_20080312_0300_000.grb output=narr) I get the following errors:
Datum not recognized by GRASS and no parameters found
Over-riding projection check
G_set_window(): Illegal latitude for North
Anyone have any experience reading NARR data into GRASS? I’ve been successful at importing other forms of grib data into GRASS; I’m not sure why this data is not working.
Katie
On Tue, Nov 3, 2009 at 2:59 PM, Carbonari, Katie (IS)
<Katie.Carbonari@ngc.com> wrote:
Good morning. I'm trying to layer on some NARR (North American Regional
Datum <unknown> not recognized by GRASS and no parameters found
Anyone have any experience reading NARR data into GRASS? I've been
successful at importing other forms of grib data into GRASS; I'm not sure
Please post the output (or relevant parts) of
gdalinfo /d1/grassdata/narr_data/narr-a_221_20080312_0300_000.grb
gdalinfo is part of GDAL but should be present on your system.
Below is the first part of the file. Thanks for your help!
Katie
Driver: GRIB/GRIdded Binary (.grb)
Files: /d1/grassdata/narr_data/narr-a_221_20080312_0300_000.grb
Size is 349, 277
Coordinate System is:
PROJCS[“unnamed”,
GEOGCS[“Coordinate System imported from GRIB file”,
DATUM[“unknown”,
SPHEROID[“Sphere”,6371200,0]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433]],
PROJECTION[“Lambert_Conformal_Conic_2SP”],
PARAMETER[“standard_parallel_1”,50],
PARAMETER[“standard_parallel_2”,50],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-107],
PARAMETER[“false_easting”,0],
PARAMETER[“false_northing”,0]]
Origin = (-5632642.225474951788783,10596359.488314554095268)
Pixel Size = (32463.000000000000000,-32463.000000000000000)
Corner Coordinates:
Upper Left (-5632642.225,10596359.488) (148d38’24.25"E, 46d38’4.34"N)
Lower Left (-5632642.225, 1604108.488) (145d23’44.80"W, 0d48’55.65"N)
Upper Right ( 5696944.775,10596359.488) ( 2d29’41.57"W, 46d 3’58.26"N)
Lower Right ( 5696944.775, 1604108.488) ( 68d14’23.82"W, 0d36’32.18"N)
Center ( 32151.275, 6100233.988) (106d33’44.57"W, 48d39’37.36"N)
Band 1 Block=349x1 Type=Float64, ColorInterp=Undefined
Description = 0[-] MSL (Mean sea level)
Metadata:
GRIB_UNIT=[Pa]
GRIB_COMMENT=Mean sea level pressure (ETA model) [Pa]
GRIB_ELEMENT=MSLET
GRIB_SHORT_NAME=0-MSL
GRIB_REF_TIME= 1205290800 sec UTC
GRIB_VALID_TIME= 1205290800 sec UTC
GRIB_FORECAST_SECONDS=0 sec
-----Original Message-----
From: neteler.osgeo@gmail.com on behalf of Markus Neteler
Sent: Tue 11/3/2009 3:07 PM
To: Carbonari, Katie (IS)
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] problem importing narr data into GRASS
