[GRASS-user] problem in grd output file
Hello
I used this command to create GMT map.
r.out.bin -h input=elv1 output=el2.grd.
But GMT's grdinfo command gives
$ grdinfo el2.grd
grdinfo: Not a netCDF file [el2.grd]
How can I produce GMT compatible grid file?
regards
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
On Friday 08 September 2006 12:29, temiz wrote:
Hello
$ grdinfo el2.grd
regards
Ahmet Temiz
Ahmet,
There are two ways to do this, both of which I will be discussing in a soon to
be finished :wink: article for the GRASS newsletter.
in summary:
#hackish way see this:
http://169.237.35.250/~dylan/grass_user_group/map1.html
#for a better approach, use r.out.bin | xyz2grd :
MAP_TYPE=`r.info -t "$output_raster" | cut -f2 -d'='`
case "$MAP_TYPE" in
  CELL)
r.out.bin input=$output_raster output=- null=-9999 |
xyz2grd -G$output_raster.grd -R$min_x/$max_x/$min_y/$max_y -I$ewres/$nsres -ZTLh -F -N-9999
  FCELL)
xyz2grd -G$output_raster.grd -R$min_x/$max_x/$min_y/$max_y -I$ewres/$nsres -ZTLf -F -N-9999 ;;
  DCELL)
xyz2grd -G$output_raster.grd -R$min_x/$max_x/$min_y/$max_y -I$ewres/$nsres -ZTLd -F -N-9999 ;;
esac
attached is a sample script, which will be presented in the newsletter article
soon.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
(attachments)
template.sh (15 KB)
I recently had a similar problem, so I thought I'd share what I just learned. In my case, the problem occurred when I tried to import a GMT grid using the command
r.in.bin -f -h input=../Documents/Mudflats_raw/Surface.grd output=Surface
r.in.bin complained that "east must be larger than west". It turns out that GMT is capable of reading and writing more than one Grdfile format. The default for GMT is to read and write grd files in the nf format (GMT netCDF format (float) (COARDS-compliant)). It looks like grass doesn't use this format, but instead reads and writes in the bf format (GMT native, C-binary format (float)). So, to use this format you have to explicitly tell GMT which format the file is (ie -GSurface.grd=bf) on the command line or set GRID_FORMAT in your .gmtdefaults4 file. It's all explained in section 4.17 of the "GMT Technical Reference and Cookbook".
Mike
Hello
$ grdinfo el2.grd
regards
Ahmet Temiz
Ahmet,
in summary:
case "$MAP_TYPE" in
  CELL)
  FCELL)
  DCELL)
esac
soon.
Dylan Beaudette
530.754.7341
<template.sh>
grassuser mailing list
grassuser@grass.itc.it
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection aroundhttp://mail.yahoo.com
