So that I can replicate, what does 'dpkg -l grass' from a
Terminal window say about the exact package version? (i.e. is
the package from ubuntugis or grass ppa or ...?) You may need
to pull the terminal window very wide to avoid the end of the
version number from being chopped off.
I have the same error as Carla when installing through gui
so switched to terminal.
(I think the problem with the wxGUI python version is something
to do with MODULE_TOPDIR; am looking into it)
but this still ends in an error full export attached as txt
file.
looking at the build log, it seems that the module was installed
ok, just that the `man` version of the help page failed to
install for some reason, but that is a minor inconvenience.
-> Try running it, does it work? Does 'locate r.out.kml' show it
in your addons dir?
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Description
ii grass 6.4.3rc2-2~pre Geographic Resources Analysis Support System
Checked add-ons menu in gui no sign of r.out.kml, no response from typing command in gui but locate says it’s there
thank you for doing so, the more feedback we have the more
obvious the problems and solutions will be.
I have been having trouble with add-ons in Ubuntu for ages -
Hamish’s response to Carla’s email inspired me to try again,
here’s how far I get…
First up specs:
GRASS version: 6.4.3RC2
Platform: Linux-3.2.0-37-generic-pae-i686-with-Ubuntu-12.04-precise
So that I can replicate, what does ‘dpkg -l grass’ from a
the package from ubuntugis or grass ppa or …?) You may need
file.
ok, just that the man version of the help page failed to
→ Try running it, does it work? Does ‘locate r.out.kml’ show it
in your addons dir?
First up specs:
file.
in your addons dir?
