[GRASS-user] Problem in lidar tutorial
Hello,
I have been trying to complete the lidar tutorial provided at http://grasswiki.osgeo.org/wiki/LIDAR#Micro-tutorial_for_LIDAR_data_analysis
The problem that I am facing is that when I enter the command such as this, then the response I get in the console is this.
Command ‘d.vect map=elev_lidlast_clean siz=2’ failed
Details: Sorry, <siz=> is ambiguous
What I can’t figure out is, that is the command working properly or not. I am using Grass 6.4.4 on windows 7 (64 bit).
Any help will be highly appreciated. Thanks.
–Gaurav
2015-03-06 8:21 GMT+01:00 Gaurav Parida <gparida94@gmail.com>:
Command 'd.vect map=elev_lidlast_clean siz=2' failed
What I can't figure out is, that is the command working properly or not. I
`siz` is ambiguous because there two options starting with `siz` ---
`size` and `size_column`. So you need to type `size`. I fixed
tutorial on wiki. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
