Nikos Alexandris wrote:
You got RST support? What is the output of:
gdalinfo --formats | grep RST
On Thu, 2008-01-10 at 13:19 +0000, temiz wrote:
hello
I need to export grass raster to idrisi (RST) format.
when I enter :
GRASS 6.3.cvs (bartin):~ > r.out.gdal input=asp1_cat@orkun format=RST type=Int16 output=/usr/local/loc0/mercan/aspusgs
I got same error message : with various type option :
ERROR 4: `/usr/local/loc0/mercan/aspusgs' not recognised as a supported file format.
ERROR: Cannot create [/usr/local/loc0/mercan/aspusgs] dataset using [RST]
driver.
how can I solve the problem ?
regards
thank you
hello
1. ~~~~~~~~~~~~~~
RST (rw+): Idrisi Raster A.1
2.~~~~~~~~~~~~~~~
GRASS 6.2.1 (bartin):~ > r.out.gdal input=asp1_cat@orkun format=RST output=/usr/local/loc0/mercan/asp_idrisi
Error: value <RST> out of range for parameter <format>
Legal range: AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,NITF,PAux,PNG,PNM,VRT,XPM
Description:
Exports GRASS raster data into various formats (requires GDAL)
Keywords:
raster, export
Usage:
r.out.gdal [-l] [input=string] [format=string] [type=string]
[output=string] [createopt=string[,string,...]]
[metaopt=string[,string,...]]
Flags:
-l list supported output formats
Parameters:
input Name of input raster map
format GIS format to write (case sensitive, see also -l flag)
options: AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,
default: GTiff
type file type
options: Byte,Int16,UInt16,UInt32,Int32,Float32,Float64,CInt16,
CInt32,CFloat32,CFloat64
output Name of output file
createopt creation option to the output format driver. Multiple options may be listed
metaopt metadata key passed on the output dataset if possible
Do I need to recompile the grass ?
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
