[GRASS-user] problem installing grass 6.2.1
Hi everybody,
I had to reinstall suse 10.2 (i586) running on AMD 32-bit arquitecture.
Following instrucions by Otto Dessau on:
http://download.qgis.org/qgis/suse/10.2/
I could install geos-2.2.3-1suse10.2.i586.rpm and
proj-4.5.0-2suse10.2.i586.rpm but when installing
gdal-1.4.1-0suse10.2.i586.rpm it complains about not having
libodbcinst.so.1
For some reason I am not able download from several web sites I found.
Could somebody provide me with this file?
Thanks
Jorge
Am Donnerstag, den 21.06.2007, 12:39 +0200 schrieb
grassuser-request@grass.itc.it:
Send grassuser mailing list submissions to
  grassuser@grass.itc.it
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grassuser-owner@grass.itc.it
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grassuser digest..."
Today's Topics:
   1. Re: g?or?f?recement ? partir d'une carte d?ja g?or?f?renc?e
      (Mamadou Diallo)
   2. d.zoom (Camilo Alcantara)
   3. problem with v.patch (Leonardo Lami)
   4. problem with r.in.wms (Maximilian Krambach)
   5. Re: problem with r.in.wms (Ivan Shmakov)
   6. Re: g?or?f?recement ? partir d'une carte d?ja g?or?f?renc?e
      (Moritz Lennert)
   7. Re: problem with r.in.wms (Agustin Diez Castillo)
Message: 1
Date: Wed, 20 Jun 2007 16:55:22 +0200
Subject: Re: [GRASS-user] g?or?f?recement ? partir d'une carte d?ja
  g?or?f?renc?e
To: "beryouni khadija" <beryouni_khadija@yahoo.fr>, "list grass user"
  <grassuser@grass.itc.it>
Message-ID: <002801c7b34b$0767c9f0$371dd29b@Mamadou>
Content-Type: text/plain; charset="iso-8859-1"
Slt
Il faut voir si a peut t'aider:
3 Gocoder une carte scanne (4 points d'angle) : carte topographique au 1:24000
GRASS peut servir gorfrencer des couches livres sans rfrencement (par exemple, si elles ont t scannes) en dfinissant des points d'amer au sol. Cette carte scanne devra tre importe dans un Secteur XY sans projection dfinie. Ce secteur peut tre cr automatiquement en utilisant la commande r.in.gdal partir d'un Secteur quelconque. En utilisant le paramtre "Secteur", la commande ne se contentera pas seulement d'importer la couche, mais galement de l'inscrire dans un nouveau Secteur (voir partie 3.1.5). Ensuite, il vous faut relancer GRASS avec le nouveau Secteur XY contenant la carte scanne. Nous allons maintenant donner les grandes lignes de la procdure sans trop s'attarder sur le dtail des oprations :
  a.. Le couche scanne doit tre intgre un groupe d'images (i.group; mme s'il s'agit d'une couche isole).
  b.. Le groupe est associ un Secteur de destination (i.target).
  c.. L'utilisateur ouvre un moniteur GRASS et place l'aide de la souris des points d'amer (i.points ou i.vpoints). La couche non rfrence est charge dans la partie gauche de l'affichage graphique, tandis que la couche rfrence est charge dans la partie droite. Pour une couche qui ne prsente pas de dformation gomtrique, quatre points chacun des angles devrait suffire.
  d.. La couche non-gorfrence est recale dans le Secteur de rfrence. (i.rectify). La complexit polynomiale pour un recalage utilisant 4 points est d'ordre 1.
Une fois le recalage termin, vous devez quitter GRASS et le relancer avec le Secteur de rfrence. L'opration peut prsent tre valide.
Au revoir tu pourras aussi voir le logiciel franais geoconcept
  ----- Original Message -----
  To: list grass user
  Sent: Wednesday, June 20, 2007 3:22 PM
  Subject: [GRASS-user] gorfrecement partir d'une carte dja gorfrence
  bonjour,
  j'ai une question concernant le gorfrecement partir d'une carte dja gorfrence: comment dois-je faire pour afficher dans un moniteur graphique la fois la carte gorfrence et photographie arienne que je veux caller? je vous cris la procdure que j'ai suivi et vous me dites SVP ce que je dois modifier ou ajouter:
  r.in.gdal pour importer la photo aerienne
  i.group pour cer un groupe et choisir ses rasters
  i.target
  d.mon start=x0
  i.points
  j'ai fait a pour le premire fois en choisissant la photo aerienne seule ds les raster du gooupe (i.group) donc dans le moniteur graphique j'avais seulement la photo aerienne, j'ai refait le travail en choisissant la photo et la carte dans le groupe (i.group) donc j'avais les deux dans le moniteur graphique mais je ne pouvait afficher qu'une seule alors que je veux les deux affiches pour que je puisse choisir les points de callage.
  merci d'avance
  Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail
URL: http://grass.itc.it/pipermail/grassuser/attachments/20070620/fb282ce4/attachment-0001.html
Message: 2
Date: Wed, 20 Jun 2007 20:38:17 -0500
From: "Camilo Alcantara" <camilo@pcbiol.posgrado.unam.mx>
Subject: [GRASS-user] d.zoom
To: grassuser@grass.itc.it
Message-ID:
  <89671eb50706201838i250ab813s662290190e2aaf60@mail.gmail.com>
Hi
I would like to report a small bug in d.zoom. While panning, with the
command "d.zoom -p" over any image on a regular monitor (e.g x1), the region
is "shrinking" by one pixel on each side of the window. It is not a big deal
when panning a map once or two times, but if panning is done several times
to explore at a larger scale a map it could be annoying.
Best
Pedro Camilo Alcntara Concepcin
Department of Forest Ecology and Management
Rm. 120 Russell Labs
1630 Linden Dr.
Madison WI 53706-1598
Phone +1/608/265-9219
http:/silvis.forest.wisc.edu
___________________________________________
URL: http://grass.itc.it/pipermail/grassuser/attachments/20070620/d7e90e03/attachment-0001.html
Message: 3
Date: Thu, 21 Jun 2007 09:58:45 +0200
Subject: [GRASS-user] problem with v.patch
To: GRASS-user <grassuser@grass.itc.it>
Message-ID: <467A2FB5.2050301@faunalia.it>
Content-Type: text/plain; charset=ISO-8859-15
I seen a bug in v.patch. If I use two or more simple vectors it works
well but if I use I see big problem in the topology of the output. This
in 6.2.1 and in 6.3 version.
I add a link to a dataset with 2 vectors to make testing.
www.faunalia.it/download/vpatch.tar.gz
Thank you
Leonardo
Message: 4
Date: Thu, 21 Jun 2007 11:01:50 +0200
From: "Maximilian Krambach" <Maximilian.Krambach@gmx.de>
Subject: [GRASS-user] problem with r.in.wms
Message-ID: <20070621090150.101430@gmx.net>
I cannot get r.in.wms into getting me a wms layer imported. The projection settings match, the layer is avaible for the region. Am I doing something wrong?
Input:
r.in.wms -kp mapserver=http://wms.jpl.nasa.gov/wms.cgi output=bmng.wms.jul layers=BMNG styles=Jul
output:
wms.request -p 'folder=/home/mate/wms_download' 'prefix=wms.bmng.jul'\
'mapserver=http://wms.jpl.nasa.gov/wms.cgi’ 'layers=BMNG' 'styles=Jul' \
'srs=EPSG:4326' 'format=geotiff' 'wmsquery=version=1.1.1' 'maxcols=1024'\
'maxrows=1024'
Calculating tiles
/usr/lib/grass/etc/r.in.wms//wms.request: 326: SIZE_ARRAY[0]=: not found
/usr/lib/grass/scripts/r.tileset: 193: declare: not found
/usr/lib/grass/scripts/r.tileset: 258: Syntax error: Bad for loop variable
Requesting 0 tiles!
wms.download 'requestfile=/home/mate/wms_download/wms.bmng.jul_.wget' 'wgetoptions=-c -t 5 --user-agent=MSIE5.5'
Downloading tiles
All tiles downloaded successfully
r.in.gdalwarp -c -k -p 'output=wms.bmng.jul' 'method=nearest' 's_srs=EPSG:4326'
ERROR: Required parameter <input> not set:
    (Raster file or files to be imported. If multiple files are specified they will be patched together.).
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal fr Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Message: 5
Date: Thu, 21 Jun 2007 16:16:28 +0700
Subject: Re: [GRASS-user] problem with r.in.wms
Message-ID:
  <b1e3a35f0706210216p271090d1jcb8da6651f35601e@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>>> "MK" == Maximilian Krambach <Maximilian.Krambach@gmx.de> writes:
        Looks like a sh/dash/bash problem? What's the first line of
        /usr/lib/grass/scripts/r.tileset? E. g.:
$ head -n1 /usr/lib/grass/scripts/r.tileset
Message: 6
Date: Thu, 21 Jun 2007 11:20:22 +0200
From: Moritz Lennert <mlennert@club.worldonline.be>
  g?or?f?renc?e
To: Mamadou Diallo <Mamadou.Diallo@unizar.es>
Cc: list grass user <grassuser@grass.itc.it>, beryouni khadija
Message-ID: <467A42D6.4080905@club.worldonline.be>
[responding in French, inviting the senders to use the French-speaking
mailing list]
Comme dj dit prcdemment Khadija: toutes les listes de GRASS
(grass-user, wingrass, grass-dev) sont des listes anglophones. Y poster
des messages en franais est fortement dcourag !
Si vous voulez discuter des questions concernant GRASS en franais,
veuillez utiliser la liste francophone qui est l pour a:
http://www.linux-nantes.fr.eu.org/mailman/listinfo/grass-fr
Merci !
Moritz
Mamadou Diallo wrote:
> Slt
> <http://www.gdf-hannover.de/lit_html/nutshell_v10_fr/node15.html#sec:auto_generate_location&gt;\).
> * Le couche scanne doit tre intgre un groupe d'images
> * Le groupe est associ un Secteur de destination (i.target).
> * L'utilisateur ouvre un moniteur GRASS et place l'aide de la
> * La couche non-gorfrence est recale dans le Secteur de
> *From:* beryouni khadija <mailto:beryouni_khadija@yahoo.fr>
> *To:* list grass user <mailto:grassuser@grass.itc.it>
> *Sent:* Wednesday, June 20, 2007 3:22 PM
> *Subject:* [GRASS-user] gorfrecement partir d'une carte dja
> gorfrence
> bonjour,
> i.target
> d.mon start=x0
> i.points
> merci d'avance
> <http://www.trueswitch.com/yahoo-fr/&gt; vers Yahoo! Mail
Message: 7
Date: Thu, 21 Jun 2007 12:32:47 +0200 (CEST)
To: "Maximilian Krambach" <Maximilian.Krambach@gmx.de>
Cc: grassuser@grass.itc.it
Message-ID: <2975192826adiez@uv.es>
Content-Type: text/plain; charset="ISO-8859-1"
This issue have been discussed on the dev-list without solution as far
as I can say.
see an example:
> same command I got a somewhat different error
# skipped region setting
r.in.wms output=terraserver-drg
mapserver=http://terraserver.microsoft.com/ogcmap6.ashx
layers=DRG format=tiff
> r.in.gdalwarp -c 'input=/Users/Shared/grassdata/wms_download/
> ERROR 1: TIFFFetchDirectory:/Users/Shared/grassdata/wms_download/
> terraserver-drg_rural_1m_0.tiff: Can not read TIFF directory count
> ERROR 1: TIFFReadDirectory:/Users/Shared/grassdata/wms_download/
> terraserver-drg_rural_1m_0.tiff: Failed to read directory at offset 0
> ERROR 4: `/Users/Shared/grassdata/nc_spm_05/user1/.tmp/
> regadiuet.prearq.uv.es/16540.0warped.geotiff' does not exist in the
> file system,
> and is not recognised as a supported dataset name.
same here, downloaded TIFF contains junk: (903K binary file)
$ tiffinfo wms_download/terraserver-drg__0.tiff
TIFFReadDirectory: wms_download/terraserver-drg__0.tiff: Can not read
TIFF directory
count.
$ gdalinfo wms_download/terraserver-drg__0.tiff
ERROR 1: TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can
not read TIFF
directory count
GDALOpen failed - 1
TIFFReadDirectory:wms_download/terraserver-drg__0.tiff: Can not read
TIFF directory
count
So the problem is not new. I'm wondering if somebody can use r.in.wms
in consistent basis. I've only been able to reproduce some of the
manual entries, when trying with other wms servers working in,for
instance, Qqis I got different errors, see above.
> Input:
> output:
'styles=Jul' \
'maxcols=1024'\
> 'maxrows=1024'
> Calculating tiles
variable
> Requesting 0 tiles!
> wms.download
> Downloading tiles
's_srs=EPSG:4326'
End of grassuser Digest, Vol 14, Issue 21
