Regie wrote:
I have been trying to install the GRASS AddOns (in particlar I'd like
to install i.landsat.toar) but no luck so far. I've done lots of searches
on the web but no solution has worked for me. I've installed GRASS 6.4.2
(from the UbuntuGIS unstable repository) on Ubuntu 12.04. I tried
installing the AddOns using the GUI.
David:
Hi, I had the same problem and the only way that I could find in order to
install Grass Addons on Ubuntu, was compiling Grass from source.
I am probably the one to fix that. Could you give me some more details
please:
* this is the version with "grass-core" and "grass-gui" packages, yes?
* is the "grass-dev" package installed? it is needed.
* what is the exact error message you get? (full cut and paste is best)
* Are you using g.extension from the command line, or from the wxGUI?
(they are different)
* if you look in the /usr/lib/grass64/include/Make/Platfrom.make file,
do GRASS_HOME and RUN_GISBASE point to /usr/lib/grass64 or somewhere else?
If the grass-dev package _is_ installed, please file a bug in the trac
system for this with as much info as possible:
https://trac.osgeo.org/grass/newticket
(newer versions of the 6.4.2 package will give you a warning when you
try to use g.extension.sh from the command line without the grass-dev
package installed; I still need to add the deb patch for g.ext.py ver)
thanks,
Hamish
