[GRASS-user] Problem installing grass7 AddOn
I have just installed r.sun.daily grass addon following the instructions described in https://grasswiki.osgeo.org/wiki/AddOns.
As you can see in the console message the installation was successful:
(Thu Feb 09 12:56:20 2017)
g.extension extension=r.sun.daily operation=add
Downloading precompiled GRASS Addons <r.sun.daily>…
Updating addons metadata file…
Installation of <r.sun.daily> successfully finished
(Thu Feb 09 12:56:22 2017) Command finished (2 sec)
Also, if I check the list of extensions installed I get this result:
C:> g.extension -a
List of installed extensions :
r.sun.daily
But, when I try to execute r.sun.daily inside a python script it seems like the addon was not installed.
As a example, this is the command that I have been using …
gscript.run_command(“r.sun.daily”, flags = “t”, elevation = “dsm”, aspect = “aspect”, slope = “slope”, … )
And this is the error message:
OSError: Cannot find the executable r.sun.daily
should i have to do anything more to finish the installation properly ?
Many thanks in advance,
A.
Hi Anna,
Anna Muñoz wrote
<r.sun.daily>
Updating addons metadata file...
Installation of
<r.sun.daily>
C:\> g.extension -a
<modules>
r.sun.daily
like
As a example, this is the command that I have been using ...
gscript.run_command("r.sun.daily", flags = "t", elevation = "dsm", aspect
"aspect", slope = "slope", ... )
just tested here with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r70508
Build date: 2017-01-09
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
I've installed r.sun.daily by g.extension, g.extension -a showed the
installed addon,
but a look in C:\Users\your_user_name\AppData\Roaming\GRASS7\addons\scripts,
where the addon are stored, there was no installed r.sun.daily addon.
check in your addon folder if the addon is installed.
my next steps were:
g.gisenv set=DEBUG=3
have a look in the debug output if there is some warning/error message
during installation.
here on my side, with DEBUG=3 the addon was installed then.
then I've done g.gisenv set=DEBUG=0
deinstalled the addon and installed r.sun.daily again, checked it in
the addon was installed correctly.
please try the steps above and report back.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-grass7-AddOn-tp5307176p5307268.html
Many thanks for your answer Helmut !
I have been following the steps that you describe but unfortunately without
success.
In my case, the solution was to set GRASS_ADDON_BASE and GRASS_PYTHON
environment variables inside my python code.
Best regards,
Anna
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-grass7-AddOn-tp5307176p5325703.html
