HI!
i convert the raster map to vector map and the name of new vect map is map_tf_v
but when i use the display command i am getting following error
g.region vect=map_tf_v
ERROR: Cannot open old vector map_tf_v@PERMANENT on level 2
d.vect map=tgr_shp
The bounding box of the map is outside the current region, nothing drawn.
how can i display the map…???
Thanks & Regards
Kunal Malik
09871147561
Kunal Malik píše v Út 26. 02. 2008 v 16:56 +0530:
HI!
map_tf_v
d.vect map=tgr_shp
drawn.
how can i display the map...???
Thanks & Regards
could you post the commands, you used, for graster->vector conversion?
What is your platform? What is your GRASS version?
jachym
P.S. Are you sure, you want to send this message to mapserver-users as
well?
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
I have use this command
GRASS 6.2.3 (spearfish60):~ > r.to.vect
and in the r.to.vect window i have enter the raster map which is converted into vector format from the raster map present in the spearfish60 database and the enter the name for the output vector map and the feature line ,after the execution all these i am getting the name of the map in the vector list .
But when i execute the instruction of display of map i am geetting error.
d.vect map=tgr_shp
drawn.
The Platform Used is Red Hat Enterprise Linux.
Grass Version=6-2.3
HI!
map_tf_v
d.vect map=tgr_shp
drawn.
Thanks & Regards
jachym
well?
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
hm,
are you working on raster map's region?
does v.info say anything?
try to run r.to.vect in command line (see r.to.vect --help for details)
and post resulting messages from this module
jachym
Kunal Malik píše v Út 26. 02. 2008 v 17:58 +0530:
error.
> d.vect map=tgr_shp
> drawn.
Grass Version=6-2.3
> HI!
vect map is
> map_tf_v
error
> d.vect map=tgr_shp
nothing
> drawn.
> Thanks & Regards
conversion?
jachym
mapserver-users as
well?
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Hi!
Thanks For ur support .
I will Try it.
I have Taken a sample Code from http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
after compilation of this code …after making setting in the Make file,
I am getting the Error
ERROR: MAPSET PERMANENT - permission denied
why this error is showing.
it create a directory “OBJ.i686-pc-linux-gnu”.containg main.o
HOW COULD I GET THE EXE.
hm,
are you working on raster map’s region?
jachym
error.
d.vect map=tgr_shp
drawn.
Grass Version=6-2.3
HI!
vect map is
map_tf_v
error
d.vect map=tgr_shp
nothing
drawn.
Thanks & Regards
conversion?
jachym
mapserver-users as
well?
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
Jachym Cepicky
Thanks & Regards
Kunal Malik
09871147561
