Hello,
It seems there is a problem when I am trying to run a python script in
GRASS GIS (every script I tried)...
...the error is:
File "C:\GRASS6.5.SVN\Python25\lib\threading.py", line 13,
in <module>
from collections import deque
ImportError: No module named collections
But if I try to run the import command directly from the IDLE python shell (from collections import deque) it seems that the module is existing and loaded properly.
I am working on Windows 7 with GRASS 6.5SVN and Pyhon 2.6.5
What is there the problem?
Thanks for any help
johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
...the error is:
in <module>
GRASS "bundles" Python 2.5. Even when this works, it doesn't work
correctly.
Unfortunately, there isn't a simple option for running GRASS on
Windows at the moment. The official Windows packages for GRASS are
quite badly broken, and doing it yourself is a lot of work.
