[GRASS-user] problem setting region in 6.4 rc3
Hello,
I'm using William Kyngesburye's OSX binaries of Grass 6.4 rc3, and find it doesn't work with my existing mapsets. On displaying a vector map, it gives an error "Error setting region: child process exited abnormally." If I set or display the region with g.region or g.region -p, I get the error "region for current mapset <projection field missing> xx run "g.region" The mapset is UTM zone 35, and works fine in 6.3. I installed the newest GDAL framework (1.6.0-5). I had thought the projection information was in one or more of the files in the mapset PROJ_INFO, etc., which are (for one typical mapset):
DEFAULT_WIND:
proj: 1
zone: 35
north: 1
south: 0
east: 1
west: 0
cols: 1
rows: 1
e-w resol: 1
n-s resol: 1
top: 1
bottom: 0
cols3: 1
rows3: 1
depths: 1
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
PROJ_INFO:
datum: wgs84
towgs84: 0.000,0.000,0.000
proj: utm
ellps: wgs84
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572235630
zone: 35
PROJ_UNITS
unit: meter
units: meters
meters: 1.0
WIND
proj: 1
zone: 35
north: 44865376.2790889
south: 4026393.07584904
east: 12546112.5351774
west: -1477754.5340503
cols: 184585
rows: 442103
e-w resol: 75.97511753
n-s resol: 92.37436345
top: 1759.33
bottom: 0
cols3: 184585
rows3: 442103
depths: 1759
e-w resol3: 75.97511753
n-s resol3: 92.37436345
t-b resol: 1.00018487'
I'm not sure why the default window sets it to one row and one column, but it works OK in 6.3. Any idea what's wrong here?
Many thanks,
Nick Cahill
