I am trying to import E00 file in GRASS GIS Version 6.1 cvs. The application asked me to download the avcimport and E00Convert from http://avce00.maptools.org/. I copied the avcimport.exe e00conv.exe to cygwin\bin. However, during import, the error “Cannot open data source: bldg An error occurred. Stop.” was still prompted out as attached. Do you have any idea, how can the problem be solved?
"Cannot open data source: bldg An error occurred. Stop." was still
problem be solved?
Thanks in advance.
Raymond
problem be solved?
yes. it is latest 6.1 version. I have installed v.in.e00 into the application, but deson’t work as the screen dump. It is ok when I run the v.in.e00 separately(i.e. the coverage can be generated.
problem be solved?
