Hi
Thanks for the help to get Grass7 running on my laptop.
I followed the workaround "sudo apt-get install grass70-core
grass70-gui" and now have grass70 running on Ubuntu 14.04 LTS:
I am trying to use the v.krige command in Grass7, and when doing so
receive the following:
Loading dependencies, please wait...
Checking rgeos availability: FALSE
Note: when rgeos is not available, polygon geometry
computations in maptools depend on gpclib,
which has a restricted licence. It is disabled by default;
to enable gpclib, type gpclibPermit()
ERROR: R package(s) rgeos, gstat, spgrass6 missing. Install it/them and
re-run v.krige.
I've installed python-rpy2.2.3.9-1 via the Ubuntu package manager, and
enabled gpclib.
Following the instructions in
http://grass.osgeo.org/grass65/manuals/v.krige.py.html I've typed in
install.packages("rgeos", dep=T)
install.packages("gstat", dep=T)
install.packages("spgrass6", dep=T)
install.packages("automap", dep=T)
Unfortunately I'm getting errors in the installation of "rgeos",
"gstat", "spgrass6", and "automap", which are detailed below. Does
anyone know where I might be going wrong. The version of R installed on
my laptop is R version 3.0.2 (2013-09-25) -- "Frisbee Sailing", and I
have a version of RKward also installed.
I am neither a Grass nor R expert, needless to say....
Installing package into ‘/home/john/R/i686-pc-linux-gnu-library/3.0’
(as ‘lib’ is unspecified)
also installing the dependency ‘XML’
downloaded 1.5 Mb
downloaded 234 Kb
* installing *source* package ‘XML’ ...
** package ‘XML’ successfully unpacked and MD5 sums checked
checking for gcc... gcc
checking for C compiler default output file name... rm: cannot remove
'a.out.dSYM': Is a directory
a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for sed... /bin/sed
checking for pkg-config... /usr/bin/pkg-config
checking for xml2-config... no
Cannot find xml2-config
ERROR: configuration failed for package ‘XML’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/XML’
* installing *source* package ‘rgeos’ ...
** package ‘rgeos’ successfully unpacked and MD5 sums checked
configure: CC: gcc -std=gnu99
configure: CXX: g++
configure: rgeos: 0.3-4
checking for /usr/bin/svnversion... no
configure: svn revision: 450
checking geos-config usability... ./configure: line 2056: geos-config:
command not found
no
configure: error: geos-config not usable
ERROR: configuration failed for package ‘rgeos’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/rgeos’
The downloaded source packages are in
‘/tmp/RtmpRYggF0/downloaded_packages’
Warning messages:
1: In install.packages("rgeos", dep = T) :
installation of package ‘XML’ had non-zero exit status
2: In install.packages("rgeos", dep = T) :
installation of package ‘rgeos’ had non-zero exit status
also installing the dependencies ‘spacetime’, ‘rgdal’, ‘rgeos’
downloaded 2.2 Mb
downloaded 1.5 Mb
downloaded 234 Kb
downloaded 2.0 Mb
* installing *source* package ‘rgdal’ ...
** package ‘rgdal’ successfully unpacked and MD5 sums checked
configure: CXX: g++
configure: rgdal: 0.8-15
configure: svn revision: 498
configure: gdal-config: gdal-config
checking gdal-config usability... ./configure: line 2119: gdal-config:
command not found
no
Error: gdal-config not found
The gdal-config script distributed with GDAL could not be found.
If you have not installed the GDAL libraries, you can
download the source from http://www.gdal.org/
If you have installed the GDAL libraries, then make sure that
gdal-config is in your path. Try typing gdal-config at a
shell prompt and see if it runs. If not, use:
--configure-args='--with-gdal-config=/usr/local/bin/gdal-config'
with appropriate values for your installation.
ERROR: configuration failed for package ‘rgdal’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/rgdal’
configure: CXX: g++
command not found
no
ERROR: dependency ‘rgeos’ is not available for package ‘spacetime’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/spacetime’
ERROR: dependency ‘spacetime’ is not available for package ‘gstat’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/gstat’
Warning messages:
1: In install.packages("gstat", dep = T) :
installation of package ‘rgdal’ had non-zero exit status
2: In install.packages("gstat", dep = T) :
3: In install.packages("gstat", dep = T) :
installation of package ‘spacetime’ had non-zero exit status
4: In install.packages("gstat", dep = T) :
installation of package ‘gstat’ had non-zero exit status
also installing the dependencies ‘XML’, ‘rgdal’
downloaded 1.5 Mb
downloaded 1.5 Mb
downloaded 268 Kb
a.out
configure: CXX: g++
command not found
no
ERROR: dependency ‘XML’ is not available for package ‘spgrass6’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/spgrass6’
Warning messages:
1: In install.packages("spgrass6", dep = T) :
2: In install.packages("spgrass6", dep = T) :
3: In install.packages("spgrass6", dep = T) :
installation of package ‘spgrass6’ had non-zero exit status
downloaded 1.5 Mb
downloaded 1.5 Mb
downloaded 268 Kb
a.out
configure: CXX: g++
command not found
no
Warning messages:
On Wed, Aug 27, 2014, at 10:10 PM, Markus Neteler wrote:
On Wed, Aug 27, 2014 at 9:08 PM, César Augusto Ramírez Franco
<caesarivs@gmail.com> wrote:
> I don't know why, but there appears to be a conflict between grass70 and
> grass70-core packages.
> I've been using that PPA on 14.04 but the package grass70 is not installed
> in my system:
> And grass is working OK, so I'd say the workaround should be issuing:
> sudo apt-get install grass70-core grass70-gui
pgis@pgis-ubuntu64-vm:~$ sudo apt-get install grass70-core grass70-gui
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not going to
be installed
Depends: libproj0 (>= 4.8.0-1) but it is not going to
be installed
Recommends: gdal-bin but it is not going to be installed
Recommends: proj-bin but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
... also failing today (Ubuntu 12.04 here)
grass-user mailing list
grass-user@lists.osgeo.org
http://www.fastmail.fm - Same, same, but different...
