[GRASS-user] problem with column label using r.cross
Dear GRASS user,
I use r.cross for combining the raster data values of up to 9 layers/maps. The
combinations are stored in column label of each new generated area. But column
label seems to be limited to a specific number of characters, so that some
information get lost in my case of 9 combining maps. My label column only shows
a subpart like:
category 2; category 3; category 2; category 0; category 0; category 9; category
Something is missing in every row. How to solve it?
Thanks a lot for any help!
Christian.
This mail was sent through http://webmail.uni-jena.de
9 layers/maps. The combinations are stored in column label of each
new generated area. But column label seems to be limited to a specific
number of characters, so that some information get lost in my case of 9
combining maps. My label column only shows a subpart like:
(above ends at the 80th character)
how are you viewing the cats? where does that cut-short line come from?
I have just done a little test, and it seemed to write the cats file ok.
Both raw if you look in the $MAPSET/cats/$MAPNAME file and printed with r.category. Only issue I found was that the cats file was huge and things like r.info took a long time. As I used fake data I won't worry about that.
my test:
g.region n=4925010 s=4913700 w=589980 e=603000 res=30
for i in `seq 10` ; do
   r.surf.gauss out=surf.gauss_tmp_$i
   r.mapcalc "surf.gauss_$i = int( surf.gauss_tmp_$i )"
   g.remove surf.gauss_tmp_$i --quiet
done
r.cross input=`g.mlist rast pat=surf.gauss_* sep=,` output=surf.gauss.x
Hamish
Ok and thanks, better to look at first within GRASS if eveything is working fine
:wink: (in cats/ full category values) Because the reduced line comes from QGIS
(selection tool). I forgot to say that following r.cross I do a conversion with
r.to.vect and export the result to a shapefile. So the original label vals were
mapped to dbf-column type "C". But why exporting only 80 chars?
Christian.
category
my test:
done
Hamish
Just now I read in the gdal description for shapefile driver:
"String fields without an assigned width are treated as 80 characters."
How can I modify that?
Christian.
category
my test:
done
Hamish
Christian Schwartze
comes from QGIS
Does v.db.select show the cut string?
which DB backend? (dbf?)
"db.describe -c vect_map" ?
Hamish
> Christian Schwartze
> comes from QGIS
v.db.select shows the full length of column label for all data rows - nothing is
missing. I use dbf backend.
ncols:3
Column 1:cat:INTEGER
Column 2:value:INTEGER
Column 3:label:CHARACTER
Christian.
Hamish
