[GRASS-user] Problem with d.vect.Please Help...
Hello,
I 'm using Grass 6.1 cvs with cygwin . I imported a shapefile from ArcMap. I’ve changed the region, open a monitor and then i tried to display the vector with the d.vect. The problem is that the vector is not finish diplaying and the monitor freezes without displaying the whole vector. Do u have any ideas. It’s a big problem cause i can’t see any vectors i’m trying to display. Is it a cygwin problem ? I’ve unistall and install the program but nothing. Thanks in advance.
×ñçóéìïðïéåßôå Yahoo!
ÂáñåèÞêáôå ôá åíï÷ëçôéêÜ ìçíý ìáôá (spam); Ôï Yahoo! Mail äéáèÝôåé ôçí êáëýôåñç äõíáôÞ ðñïóôáóßá êáôÜ ôùí åíï÷ëçôéêþí ìçíõìÜôùí
http://login.yahoo.com/config/mail?.intl=gr
ArcMap. I've changed the region, open a monitor and then i tried to
the whole vector. Do u have any ideas. It's a big problem cause i
can't see any vectors i'm trying to display. Is it a cygwin problem
? I've unistall and install the program but nothing. Thanks in
advance.
Strange.
g.region vect=yourmap
How complicated is the vector file? (v.info output?)
g.region -p
Hamish
