[GRASS-user] Problem with displaing map
on cvs updated on 22.04, 20.00
problem with displaying raster map both in monitor and map display
nviz also crashes wen I try to display raster
on d.rast map=mapa error message: Segmentation fault (core dumped)
On grass 6.2.1 (stable) all work fine
Jarek
what about "r.info mapa" ?
are all other raster maps in the same mapset ok? or bad too?
what if you create a new raster map with:
r.mapcalc one=1
or
r.mapcalc newmap=mapa
are they ok?
Hamish
r.mapcalc one=1
or
are they ok?
Hamish
I update cvs today morning, now all seems OK - maybe unreported error ocured during compilation or something similar, I don't know...
If problem will occur again I will report
Jarek
On Mon, Apr 23, 2007 at 09:58:21AM +0200, Jaros??aw Jasiewicz wrote:
Hamish napisa??(a):
Due to the many modifications in CVS, a
make distclean
and recompilation is needed. I had the same problem with d.rast
which disappeared after full recompile.
Hamish napisa??(a):
make distclean
grassuser mailing list
grassuser@grass.itc.it
Thanks Markus
now all is OK
Jarek
