Jarek Jasiewicz wrote:
D3/3: db_select_int()
D3/3: SQL: SELECT cat FROM streams_coor WHERE link::text IN(SELECT
regexp_split_to_table((SELECT branch FROM links WHERE keyid='168'), E'\\.'))
D3/3: Escaped SQL: SELECT cat FROM streams_coor WHERE link::text
IN(SELECT regexp_split_to_table((SELECT branch FROM links WHERE
keyid='168'), E'\\\\.'))
D3/3: describe_table()
As we see, there is a problem with escape \ backslash
grass (I don't know gis.m or db_select_int()) adds backslash before.
In pgAdmin I must add escape character manually as in example in post
before.
In gis.m this command should look like:
link::text IN(
SELECT branch FROM links WHERE keyid='168'), E'\.'))
And everythik is OK. Porblem solved.
db/drivers/postgres/execute.c has the following:
/* Postgres supports in addition to standard escape character ' (apostrophe) also \ (basckslash)
* as this is not SQL standard, GRASS modules cannot work escape all \ in the text
* because other drivers do not support this feature. For example, if a text contains
* string \' GRASS modules escape ' by another ' and string passed to driver is \''
* postgres takes \' as ' but second ' remains not escaped, result is error.
* Because of this, all occurencies of \ in sql are escaped by \ */
str = G_str_replace(db_get_string(sql), "\\", "\\\\");
[Note that "\\" is a string containing a single backslash, as C also
uses backslash as an escape character.]
IOW, the "pg" DBMI driver assumes that every backslash which it sees
is supposed to be a literal backslash, and converts it to a
double-backslash escape sequence to ensure that it is interpreted as
such.
So you can't use PostgreSQL's C-like escapes (\n etc) within SQL
syntax.
