[GRASS-user] problem with export of raster data
Hello
I try to export a raster integer map whose values range from -9999 to 5880712. How can i specify that i want integer 4 bytes and not integer 2 bytes (it makes integer 2 bytes)??
Thank you.
Stéphanie
On Mon, Feb 23, 2009 at 12:15 PM, FAROUX STEPHANIE
<stephanie.faroux@meteo.fr> wrote:
Hello
If you export with r.out.gdal you can choose among
      type File type
              options: Byte,Int16,UInt16,Int32,UInt32,Float32,Float64,CInt16,
                       CInt32,CFloat32,CFloat64
This is the range which GRASS support for export to GDAL
supported formats (of course it depends if the format is compatible
with the selected type, see GDAL manual pages for details).
Hello
      type File type
Yes i saw it.
However i wonder what is the difference between Uint32, Int32, CInt32? I suppose: unsigned integer 32 bits for the first, but the others?
Then, i want binary files, what should i choose among the proposed formats?
I tried with no format and with GTiff format. For example when i do: "r.out.gdal input=world_fa2 format=GTiff2 type=Int32 output=world_fa_gdal"
or "r.out.gdal input=world_fa2 format=GTiff2 type=UInt32 output=world_fa_gdal" or "r.out.gdal input=world_fa2 format=GTiff2 type=CInt32 output=world_fa_gdal"
it doesn't work and i get:
*** buffer overflow detected ***: g.parser terminated
======= Backtrace: =========
/lib64/libc.so.6(__fortify_fail+0x37)[0x2b42e8de0157]
/lib64/libc.so.6[0x2b42e8dde7e0]
/lib64/libc.so.6[0x2b42e8ddddb9]
/lib64/libc.so.6(_IO_default_xsputn+0x8e)[0x2b42e8d65b5e]
/lib64/libc.so.6(_IO_vfprintf+0x1633)[0x2b42e8d3b9b3]
/lib64/libc.so.6(__vsprintf_chk+0x9d)[0x2b42e8ddde5d]
/lib64/libc.so.6(__sprintf_chk+0x80)[0x2b42e8dddda0]
g.parser(main+0x2b9)[0x4012b9]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x2b42e8d16074]
g.parser[0x400ea9]
======= Memory map: ========
00400000-00402000 r-xp 00000000 08:01 199895 /usr/lib64/grass62/bin/g.parser
00602000-00603000 rw-p 00002000 08:01 199895 /usr/lib64/grass62/bin/g.parser
00603000-00624000 rw-p 00603000 00:00 0 [heap]
2b42e81bc000-2b42e81d6000 r-xp 00000000 08:01 65538 /lib64/ld-2.7.so
2b42e81d6000-2b42e81d8000 rw-p 2b42e81d6000 00:00 0
2b42e83d5000-2b42e83d6000 r--p 00019000 08:01 65538 /lib64/ld-2.7.so
2b42e83d6000-2b42e83d7000 rw-p 0001a000 08:01 65538 /lib64/ld-2.7.so
2b42e83d7000-2b42e8427000 r-xp 00000000 08:01 222338 /usr/lib64/grass62/lib/libgrass_gis.6.2.3.so
2b42e8427000-2b42e8626000 ---p 00050000 08:01 222338 /usr/lib64/grass62/lib/libgrass_gis.6.2.3.so
2b42e8626000-2b42e8629000 rw-p 0004f000 08:01 222338 /usr/lib64/grass62/lib/libgrass_gis.6.2.3.so
2b42e8629000-2b42e8641000 rw-p 2b42e8629000 00:00 0
2b42e8641000-2b42e8648000 r-xp 00000000 08:01 222312 /usr/lib64/grass62/lib/libgrass_datetime.6.2.3.so
2b42e8648000-2b42e8848000 ---p 00007000 08:01 222312 /usr/lib64/grass62/lib/libgrass_datetime.6.2.3.so
2b42e8848000-2b42e8849000 rw-p 00007000 08:01 222312 /usr/lib64/grass62/lib/libgrass_datetime.6.2.3.so
2b42e8862000-2b42e8876000 r-xp 00000000 08:01 65654 /lib64/libz.so.1.2.3
2b42e8876000-2b42e8a75000 ---p 00014000 08:01 65654 /lib64/libz.so.1.2.3
2b42e8a75000-2b42e8a76000 rw-p 00013000 08:01 65654 /lib64/libz.so.1.2.3
2b42e8a76000-2b42e8a77000 rw-p 2b42e8a76000 00:00 0
2b42e8a77000-2b42e8af6000 r-xp 00000000 08:01 65553 /lib64/libm-2.7.so
2b42e8af6000-2b42e8cf6000 ---p 0007f000 08:01 65553 /lib64/libm-2.7.so
2b42e8cf6000-2b42e8cf7000 r--p 0007f000 08:01 65553 /lib64/libm-2.7.so
2b42e8cf7000-2b42e8cf8000 rw-p 00080000 08:01 65553 /lib64/libm-2.7.so
2b42e8cf8000-2b42e8e43000 r-xp 00000000 08:01 65545 /lib64/libc-2.7.so
2b42e8e43000-2b42e9042000 ---p 0014b000 08:01 65545 /lib64/libc-2.7.so
2b42e9042000-2b42e9046000 r--p 0014a000 08:01 65545 /lib64/libc-2.7.so
2b42e9046000-2b42e9047000 rw-p 0014e000 08:01 65545 /lib64/libc-2.7.so
2b42e9047000-2b42e904e000 rw-p 2b42e9047000 00:00 0
2b42e904e000-2b42e908d000 r--p 00000000 08:01 565776 /usr/share/locale/UTF-8/LC_CTYPE
2b42e908d000-2b42e9094000 r--s 00000000 08:01 500251 /usr/lib64/gconv/gconv-modules.cache
2b42e9094000-2b42e9095000 r--p 00000000 08:01 565931 /usr/share/locale/fr_FR.UTF-8/LC_MESSAGES/SYS_LC_MESSAGES
2b42e9095000-2b42e90f5000 r--p 00000000 08:01 222408 /usr/lib64/grass62/locale/fr/LC_MESSAGES/grassmods.mo
2b42e90f5000-2b42e90f6000 r-xp 00000000 08:01 500166 /usr/lib64/gconv/ISO8859-1.so
2b42e90f6000-2b42e92f6000 ---p 00001000 08:01 500166 /usr/lib64/gconv/ISO8859-1.so
2b42e92f6000-2b42e92f7000 r--p 00001000 08:01 500166 /usr/lib64/gconv/ISO8859-1.so
2b42e92f7000-2b42e92f8000 rw-p 00002000 08:01 500166 /usr/lib64/gconv/ISO8859-1.so
2b42e92f8000-2b42e9305000 r-xp 00000000 08:01 65589 /lib64/libgcc_s-4.2.3.so.1
2b42e9305000-2b42e9504000 ---p 0000d000 08:01 65589 /lib64/libgcc_s-4.2.3.so.1
2b42e9504000-2b42e9505000 rw-p 0000c000 08:01 65589 /lib64/libgcc_s-4.2.3.so.1
7fffc28d7000-7fffc28ed000 rw-p 7ffffffe9000 00:00 0 [stack]
7fffc29fd000-7fffc29ff000 r-xp 7fffc29fd000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
So for the moment what i did is transforming my integer into real and exporting it as binary. Thus i get a float binary file but with the correct values....
Hello
      type File type
Yes i saw it.
I think it must be GTiff and not GTiff2. The command would be
r.out.gdal input=world_fa2 format=GTiff type=Int32 output=world_fa_gdal.tif
BTW, no format defaults to GTiff format in r.out.gdal.
UInt32 is unsigned integer 32 bit, yes. Int32 is signed integer 32 bit, CInt32 is complex signed integer 32 bit (not supported by grass). With world_fa2 (range is -9999 to 5880712, yes?), Int32 seems the right choice.
Markus M
On Tue, Feb 24, 2009 at 10:14 AM, Markus Metz
See also the "Ranges of GDAL data types" table in:
http://grass.osgeo.org/gdp/html_grass64/r.out.gdal.html
Just wanted to suggest to add it but it's already there :slight_smile:
