Dear all,
I am newby at grass. I have just compiled grass 6.2.2 from source code and I managed to compile it without a lot of problems. However, I am trying to run firedome, using the data from the website and following the instructions I found without any success. The output of the firedemo.sh script is the following:
GRASS 6.2.2RC1 (demolocation):~/grassdata/demolocation/demomapset >./firedemo.sh
Prepare for simulation:
REMOVE [my_ros.max]
raster MISSING
header MISSING
Calculate the ROS (rate of spread), etc.:
ERROR: fuel_model - not found
Spread:
ERROR: my_ros.max - not found
Spread done
I have run the script from different directories, but I didn't success...
What am I doing wrong?
Thank you very much!
Carlos Alberto Castaño Moraga
Departamento de Ingeniería del Software
INSTITUTO TECNOLÓGICO DE CANARIAS, S.A.
Playa de Pozo Izquierdo, s/n
35119 – Santa Lucía (Las Palmas), España
Tel: +34 928 727586 Fax: +34 928 727517
email: ccmoraga@itccanarias.org url: http://www.itccanarias.org
AVISO LEGAL:
Este mensaje y los ficheros adjuntos si los hubiere, se dirigen exclusivamente a su destinatario y puede contener información privilegiada o confidencial. La transmisión errónea del presente mensaje en ningún momento supone renuncia a su confidencialidad. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma vía y proceda a su destrucción.
LEGAL WARNING:
This message and the files attached if there were any, are intended exclusively for its addressee and may contain information that is CONFIDENTIAL and protected by professional privilege. A wrong transmission to this message don’t suppose we relinquished to It’s confidential. If you are not the intended recipient you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited by law. If this message has been received in error, please immediately notify us via e-mail and delete it.
