[GRASS-user] problem with g.extension
I'm trying to install an extension (v.mkhexgrid) using g.extension and after
g.extension extension=v.mkgrid
I get the following error message:
Fetching <v.mkhexgrid> from GRASS-Addons SVN (be patient)...
A v.mkhexgrid/description.html
A v.mkhexgrid/v.mkhexgrid
A v.mkhexgrid/Makefile
Checked out revision 44986.
Compiling <v.mkhexgrid>...
Makefile:5: /usr/lib/grass64/include/Make/Script.make: No such file or directory
make: *** No rule to make target `/usr/lib/grass64/include/Make/Script.make'. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
I'm on ubuntu 10.04, grass 6.4 and my $GISBASE is /usr/lib/grass64
The directory /usr/lib/grass64/include/Make/ does exists (but it is empty).
Any help?
Saludos, EKS
Eduardo Klein
Lab Sensores Remotos e
Instituto de Tecnología y Ciencias Marinas
Universidad Simón Bolívar
Caracas, Venezuela
ph (58) (212) 906-3111 ext 6700
fax (58) (212( 906-3111 ext 6701
2011/1/12 Eduardo Klein <eklein@usb.ve>:
missing grass-dev package.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thanks, you're right. But still, after installing the missing package and fixing some permissions problems, I'm getting some errors. The first of them:
make[82]: Entering directory `/home/eklein/grassdata/usb/PERMANENT/.tmp/diodon/7414.0/v.mkhexgrid'
if [ "/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/scripts/v.mkhexgrid" != "" ] ; then GISRC=/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu PATH="/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/bin:/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/lib:/usr/lib/grass64/lib" LC_ALL=C fakeroot /build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/scripts/v.mkhexgrid --html-description < /dev/null | grep -v '</body>\|</html>' > v.mkhexgrid.tmp.html ; true ; fi
ERROR: G_getenv(): Variable LOCATION_NAME not set
Any ideas?
Saludos, EKS
On 01/12/2011 11:57 AM, Martin Landa wrote:
2011/1/12 Eduardo Klein<eklein@usb.ve>:
Martin
Eduardo Klein
Caracas, Venezuela
Hi just stumbled upon your question while trying to find a way to install it
on 10.04 as well. Jumped through all the hoops to get onto this mailing list
to let you know what worked for me...
1. Download mkhexgrid-0.1.1-1.i386.rpm
2. $ sudo alien mkhexgrid-0.1.1-1.i386.rpm
3. Double click the generated .deb
Simple as that as long as you don't have 64bit of course, then you probably
still have to compile.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-g-extension-tp5915051p6097132.html
them:
!= "" ] ; then
This is a packaging error as well as bug
http://trac.osgeo.org/grass/ticket/620
and perhaps also
http://trac.osgeo.org/grass/ticket/1180
A pity that it is still open after so much time.
Markus wrote:
and perhaps also
that one has a test-fix in 6.5svn, does it work if you try that version?
Hamish
