[GRASS-user] problem with g.in.ogr
Hello all,
I have a problem with v.in.ogr.
I would like to import a shape file (with 57851 polygons) with v.in.ogr.
v.import --verbose input=/media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe.shp layer=bati_D90_decoupe output=bati_D90_decoupe -o
Visibly the order is going well, my attribute table contains 57851 attributes but when I check my vector with display, some polygons are missing.
Thanks for your help.
Camille Bezzina
Geophom
On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina <camille.bezzina@geophom.fr> wrote:
Hello all,
Can you post the full output of v.import with --verbose?
Considering that you override the projection check with -o, you can also use v.in.ogr directly and then post the full output of v.in.ogr -o --verbose.
Markus M
Camille Bezzina
Geophom
grass-user mailing list
grass-user@lists.osgeo.org
Hi Markus,
In the file attached you can find the full output of v.import with verbose.
I launch this one with v.in.ogr and this is the answer.
Thanks.
(attachments)
v.import_verbose.txt (6.13 KB)
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Chargé d’études géomatiques et photomontages
Geophom
57 rue du Chemin Neuf 44521 OUDON
Standard: +33(0)2 85 52 02 59
Ligne directe: +33(0)9 72 56 81 71
www.geophom.fr
On 12/04/18 17:03, Camille Bezzina wrote:
Hi Markus,
At the end you can see:
"Some input polygons are overlapping each other.
If overlapping is not desired, the data need to be cleaned.
The input could be cleaned by snapping vertices to each other.
Estimated range of snapping threshold: [1e-08, 1]
Try to import again, snapping with at least 1e-08: 'snap=1e-08'"
Try importing with snap=0.01 or something like that (depending on the nature and precision of your data.
Moritz
Thanks.
On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina <camille.bezzina@geophom.fr <mailto:camille.bezzina@geophom.fr>> wrote:
> Hello all,
Markus M
> Camille Bezzina
> Geophom
> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Camille BEZZINA
Chargé d'études géomatiques et photomontages
Geophom
www.geophom.fr
On Thu, Apr 12, 2018 at 6:20 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Markus,
“Some input polygons are overlapping each other.
Try to import again, snapping with at least 1e-08: ‘snap=1e-08’”
I would rather suggest snapping with a smaller value: snap=1e-4.
The main problem is close to the end, when building topology for the final output bati_D90_decoupe:
WARNING: Nombre de contours incorrects: 8772
This is the reason for disappearing polygons. This is a bug that has been fixed a while ago, please update your GRASS version to the latest 7.2 or 7.4 release.
Markus M
Moritz
Thanks.
On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina <camille.bezzina@geophom.fr mailto:[camille.bezzina@geophom.fr](mailto:camille.bezzina@geophom.fr)> wrote:
Hello all,
Markus M
Camille Bezzina
Geophom
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
Camille BEZZINA
Geophom
www.geophom.fr
I tried to import my vector with the latest version 7.4 and testing snap=0.01or other values but there is always the same problem.
I also tried with another shapefile (smaller) but it doen’t change anything.
You can find the result in the attached file (verbose + .pdf). As you can see, when I import a .shp, a lot of polygons desappear.
Camille
(attachments)
v.import_verbose.txt (4.48 KB)
difference.pdf (256 KB)
Hi Markus,
Moritz
Thanks.
On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina <camille.bezzina@geophom.fr mailto:camille.bezzina@geophom.fr> wrote:
Hello all,
Markus M
Camille Bezzina
Geophom
grass-user@lists.osgeo.org mailto:grass-user@lists.osgeo.org
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
On Wed, Apr 18, 2018 at 5:27 PM, Camille Bezzina <camille.bezzina@geophom.fr> wrote:
Can you provide off-list (a link to) the shapefile causing problems? Then we can test.
Markus M
Camille
Hi Markus,
Moritz
Thanks.
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
You can download the shapefile causing problems here : https://we.tl/qByZnpMNvU
Markus M
Camille
Hi Markus,
Moritz
Thanks.
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
On Wed, Apr 18, 2018 at 5:39 PM, Camille Bezzina <camille.bezzina@geophom.fr> wrote:
Thanks a lot!
The input is 3D, and pairs of consecutive vertices are exactly on top of each other. The data can be imported successfully with v.in.ogr -2, forcing 2D output.
In this case I don’t understand (yet) why forcing 2D is necessary.
Markus M
Markus M
Camille
Hi Markus,
Moritz
Thanks.
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Thanks a lot Markus for your help !
It works. :slight_smile:
Last question about that, the “verbose” says me that I have 57851input polygons but 58049 areas in output. Why this difference ?
How can I check if all polygons are imported ?
Thanks a lot!
Markus M
Markus M
Camille
Hi Markus,
Moritz
Thanks.
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
On Fri, Apr 20, 2018 at 10:47 AM, Camille Bezzina <camille.bezzina@geophom.fr> wrote:
The number of areas is larger than the number of polygons because holes inside polygons are also represented as areas.
What counts is the number of centroids which is ideally identical to the number of input polygons, as long as input polygons don’t overlap. In case polygons overlap, the number of centroids can be different from the number of input polygons.
Markus M
Thanks a lot!
Markus M
Markus M
Camille
Hi Markus,
Moritz
Thanks.
Hello all,
Markus M
Camille Bezzina
Geophom
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
