I've compiled grass6.4svn, and if I try to start a location with
geographics coordinate, I've this error:
GRASS 6.4.svn (EPSG_4326):~ > Error in startup script: can't read
"parts(w)": no such variable
while executing
"set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
(procedure "MapCanvas::zoom_gregion" line 16)
invoked from within
"MapCanvas::zoom_gregion $mon"
(procedure "MapCanvas::create" line 40)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 79)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.4.svn/etc/gm/gm.tcl" line 557)
This GDB was configured as "i486-linux-gnu"...
(no debugging symbols found)
(gdb) r -p
Starting program: /usr/local/grass-6.3.0/bin/g.region -p
---Type <return> to continue, or q <return> to quit---
[Thread debugging using libthread_db enabled]
warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at 000000b4
[New Thread 0xb59eb8f0 (LWP 19677)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb59eb8f0 (LWP 19677)]
0xb79a9506 in sincos () from /usr/local/lib/libgdal.so.1
(gdb)
(gdb) bt #0 0xb79a9506 in sincos () from /usr/local/lib/libgdal.so.1 #1 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #2 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #3 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #4 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #5 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #6 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #7 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #8 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #9 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #10 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #11 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #12 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #13 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #14 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #15 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #16 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #17 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #18 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #19 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #20 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #21 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1 #22 0xb79a950b in sincos () from /usr/local/lib/libgdal.so.1
2008/9/25 Markus Neteler <neteler@osgeo.org>:
On Thu, Sep 25, 2008 at 10:10 AM, Alfredo Alessandrini
<alfreale74@gmail.com> wrote:
g.region -p
and watch out for errors...
note that your previous mail indicated
