I’m doing my first steps with the R-Grass interface but…
library(spgrass6)
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.6.1, released 2009/05/11
Path to GDAL shared files: /usr/share/gdal16
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.4.0RC5
and location: monte
a=readVECT6(“area_estudio”)
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
I installed grass65 from source, is this the problem? How do I fix it?
Thanks!
Lic. Leonardo A. Hardtke
Laboratorio de Teledetección y S.I.G.
Centro Nacional Patagónico (CONICET)
Bvd. Brown 2825, 9120 Puerto Madryn, Chubut, Argentina
you need to recompile gdal-grass plugin
Leonardo Hardtke pisze:
I'm doing my first steps with the R-Grass interface but...
library(spgrass6)
and location: monte
> a=readVECT6("area_estudio")
Thanks!
grass-user mailing list
grass-user@lists.osgeo.org
