[GRASS-user] Problem with GRASS 6.4RC6 and wxPython 2.8.11 on CentOS 5.5 x86_64
Hello,
I'm working on the RPM packaging of GRASS 6.4 for Enterprise Linux
(http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS).
We rely on the EPEL repository for many libraries and since their
upgrade of wxGTK / wxPython to 2.8.11 the wx UI of GRASS is broken.
We get the stacktrace below:
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/gui_modules/wxgui_utils.py",
line 73, in __init__
    super(LayerTree, self).__init__(parent, id, pos, size,
style=style, ctstyle=ctstyle)
  File "/usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/lib/mixins/treemixin.py",
line 488, in __init__
    super(DragAndDrop, self).__init__(*args, **kwargs)
TypeError: __init__() got an unexpected keyword argument 'ctstyle'
(complete stack at the end of the mail)
This may also be due to the update of other component when updating to
CentOS 5.5, but I rather suspect the wx update.
Anyhow the wx UI was working on CentOS 5.4 with wxGTK 2.8.9 / wxPython 2.8.7 .
Can you please help me analyze this issue further?
Thanks in advance!
Mathieu
Welcome to GRASS 6.4.0RC6 (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4.0RC6 (EasternBalkans2010):~ >
WARNING: Vector digitizer is not available (No module named grass6_wxvdigit).
Note that the vector digitizer is currently not working under MS
Windows (hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS.
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 1819, in ?
    sys.exit(main())
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 1812, in main
    app = GMApp(workspaceFile)
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 1737, in __init__
    wx.App.__init__(self, False)
  File "/usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7978, in __init__
    self._BootstrapApp()
line 7552, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 1755, in OnInit
    workspace = self.workspaceFile)
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 185, in __init__
    self.NewDisplay(show=False)
  File "/usr/lib64/grass-6.4.0RC6/etc/wxpython/wxgui.py", line 1236,
in NewDisplay
    auimgr=self._auimgr, showMapDisplay=show)
Any idea on how I could analyse further what the problem is?
Maybe this list is not the right place where to ask?
Should I write to a developer mailing list directly?
wxPython 2.8.11 isn't backwards compatible with 2.8.10. It has been
discussed in slightly more detail here:
http://lists.osgeo.org/pipermail/grass-dev/2010-June/050766.html
Does this mean that we have to downgrade wxPython somehow, or can we
expect it to be fixed in GRASS 6.4 ?
Thanks for your help!
On Tue, Jun 8, 2010 at 6:35 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Apparently the suggested fix in this email has not made it into SVN.
Would it cure the problem incl. a backport to 6.4?
2010/6/8 Markus Neteler <neteler@osgeo.org>:
done in r42520 (backported to devbr6 in r42521). After some testing
can be backported to relbr64.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Mathieu,
Martin has kindly applied the patch and backported it to 6.5, could you
please take the diff and apply it to your copy to see if it works & helps?
http://trac.osgeo.org/grass/changeset/42522?format=diff&new=42522
My wxPython version is older, so that I cannot test it here.
thanks
try
http://trac.osgeo.org/grass/attachment/ticket/1085/ctstyle.diff
Martin
try
Many thanks for the patch!
I could apply it directly on the 6.4RC06 codebase
Version: 6.4.0RC6
Patch4: grass-ctstyle.patch
%patch4 -p0
and the wxUI now starts properly.
However when I now try to add, say, a raster, I get the following
error in the command output:
line 1269, in OnAddRaster
self.AddRaster(event)
line 1394, in AddRaster
self.curr_page.maptree.AddLayer('raster')
xgui_utils.py", line 678, in AddLayer
layer = self.PrependItem(parent=self.root, text='',
ct_type=1, wnd=ctrl)
packages/wx-2.8-gtk2-unicode/wx/lib/agw/customtreectrl.py",
line 4065, in PrependItem
return self.DoInsertItem(parent, 0, text, ct_type, wnd,
image, selImage, data)
line 3966, in DoInsertItem
raise Exception("\nERROR: In Order To Append/Insert Controls
You Have To Use The Style TR_HAS_VARIABLE_ROW_HEIGHT")
Exception
ERROR: In Order To Append/Insert Controls You Have To Use
Same (or similar) when adding a vector:
line 1326, in OnAddVector
self.AddVector(event)
line 1428, in AddVector
self.curr_page.maptree.AddLayer('vector')
Exception
The same operations do work with the -tcltk interface.
I think we are making good progress.
Any idea what could cause this one?
I'll be really happy to have the wxUI interface running on Enterprise Linux 5!
2010/6/16 Mathieu Baudier <mbaudier@argeo.org>:
there are more fixes in releasebranch_64, try to compile code from SVN [1].
Martin
[1] http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4
Sorry that it took me so long to come back to you.
I tested the revision 43144 of releasebranch_6_4, and the problem is
indeed solved!
The only significant modification I had to do in our spec file was
that a ChangeLog_%{version}.gz file was missing.
I guess that it is only available in releases tarballs but not in SVN, isn't it?
RPMs for i386 and x86_64 containing a build of this revision are
available in the ELGIS Testing repository (elgis-testing):
http://elgis.argeo.org
Thanks a lot for your help!
2010/8/16 Mathieu Baudier <mbaudier@argeo.org>:
yes. Martin
