Dear All,
I have been getting valuable information from the list for more than a year now. Recently, I upgraded to Fedora 6 with a clean install. I tried to run the following command but recieved an error. I would appreciate any feedback. Grass package is looking for Gdal version 1.3 libraries.
Thank you,
Sitansu
Install command:
yum localinstall grass-6.2.0-1.fdr.fc6.i386.rpm gdal-grass-1.3.2-1.fdr.fc6.i386.rpm
Output:
Loading “installonlyn” plugin
Setting up Local Package Process
Examining grass-6.2.0-1.fdr.fc6.i386.rpm: grass - 1:6.2.0-1.fdr.fc6.i386
Examining gdal-grass-1.3.2-1.fdr.fc6.i386.rpm: gdal-grass - 1:1.3.2-1.fdr.fc6.i386
Marking grass-6.2.0-1.fdr.fc6.i386.rpm to be installed
Setting up repositories
Reading repository metadata in from local files
Marking gdal-grass-1.3.2-1.fdr.fc6.i386.rpm to be installed
Resolving Dependencies
→ Populating transaction set with selected packages. Please wait.
—> Package gdal-grass.i386 1:1.3.2-1.fdr.fc6 set to be updated
—> Package grass.i386 1:6.2.0-1.fdr.fc6 set to be updated
→ Running transaction check
→ Processing Dependency: fftw3 >= 3.1 for package: grass
→ Processing Dependency: lesstif >= 0.95 for package: grass
→ Processing Dependency: proj >= 4.4.9 for package: grass
→ Processing Dependency: libgdal.so.1 for package: gdal-grass
→ Processing Dependency: proj for package: gdal-grass
→ Processing Dependency: gdal >= 1.3 for package: grass
→ Processing Dependency: geos >= 2.1.1 for package: grass
→ Restarting Dependency Resolution with new changes.
—> Package lesstif.i386 0:0.95.0-10.fc6 set to be updated
—> Package geos.i386 0:2.2.1-5.fc6 set to be updated
—> Package proj.i386 0:4.4.9-4.fc6 set to be updated
—> Package fftw.i386 0:3.1.2-3.fc6 set to be updated
→ Processing Dependency: libXp.so.6 for package: lesstif
—> Package libXp.i386 0:1.0.0-8 set to be updated
→ Finished Dependency Resolution
Error: Missing Dependency: libgdal.so.1 is needed by package gdal-grass
Error: Missing Dependency: gdal >= 1.3 is needed by package grass
