Hi Everyone,
I have a sample of 3D points (x,y,z) with tepmerature attribute. I can import my data as a 3D vector map. I want to create a volume of voxels by using v.vol.rst module. When I use this module, this warnning happens WARNING: strip exists with insufficient data Processing all selected output files will require 0 bytes of disk space for temp files
can somebody help me how to solve this problem? what is the required steps for interpolating 3D vector points to create a 3D voxel model in GRASS GIS?
Many Thanks,
Behnam
