Diane,
Have you tried to use GRASS plugin in QGIS?
Saber
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk
Tel: +44 (0)1444 848012
From: grass-user-bounces@lists.osgeo.org [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Diane Palmer
Sent: 30 January 2014 10:13
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] Problem with Python GUI Grass 6
Dear List Members
I am very new to Grass and am having a few problems getting started. I’m running it on Windows 7 Enterprise, 64 bit.
- I’ve tried the version 6.4.3 installed with QGIS.
a) In the Python GUI, when I try to add a vector or raster layer (Spearfish data, Quickstart tutorial), I don’t get a drop-down list. It adds an empty file with the message “Unable to fetch interface description for command ‘d.vect’/‘d.rast’”.
b) When I try to import a shapefile of my own, it does import it, but I can only see the attribute table, not the map. (I did remember to zoom to it and check the colour visibility). The message is “Command ‘d.vect map=UK_outline@eldp’ failed”.
- I installed WinGRASS-6.4.3-1-Setup.exe and accepted the Microsoft Runtime libraries option. The Python GUI flickers in the toolbar and then crashes. Fortunately the old TclTK GUI works.
So I have got a version which works but I’d really appreciate some suggestions on how I can get the attractive Python GUI up and running.
Many thanks.
Diane Palmer
Research Associate
CREST (Centre for Renewable Energy Systems Technology)
School of Electronic, Electrical and Systems Engineering
Loughborough University
e-mail: D.Palmer@lboro.ac.uk
T: +44 (0) 1509 635 604
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
