Dear Helmut,
thanks for your answer
Date: Sat, 1 Nov 2014 15:17:32 -0700
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Problem with python script in osgeo4w grass 6.4.4 32bit
m roy wrote
Dear all,
i made a python script for grass and it does not work in grass (version in
message subject).
The interface opens but a Windows error states that it is impossible to
open the file, the
file is hence not recognized as a valid command.
the script used to work with osgeo4w 6.4.3 32 bit, if copied in
“…/etc/gui/scripts” directory.
so far I know nothing about your script.
the script is a grass python script i made to automate some processing
and fondamentally uses r.mapcalc to perform map algebra e.g:
grass.mapcalc(“$mapoutfile = abs($inraster)”,mapoutfile=outraster+‘oname’+kf.name,inraster=outraster+‘_’+ofile.name)
why is your script in “…/etc/gui/scripts”? as it states this folder is for
GUI scripts; AFAIR this folder may be not in %PATH%.
This beacause the script have an interface generated by grass parser,
and that is the only way I found to have it run in MS Windows (that worked in grass 6.4.3)
also the scrip flawlessly works in linux.
have you any bat-wrapper for your python script in your %PATH%.
for your python script r.your.script.py living in
C:\OSGeo4W\apps\grass\grass-6.4.x\scripts the bat-wrapper-script
r.your.script.bat should be in C:\OSGeo4W\apps\grass\grass-6.4.x\bin
with following content
@“%GRASS_PYTHON%” “%GISBASE%/scripts/r.your.script.py” %*
I tried your advice, copied the script in
C:\OSGeo4W\apps\grass\grass-6.4.4\scripts
and made the bat file in
but tring tu run it i get this error:
grass output:
File “C:\OSGeo4W\apps\grass\grass-6.4.4\etc\wxpython\gui_c
ore\prompt.py”, line 840, in OnItemSelected
self.cmdDesc = gtask.parse_interface(GetRealCmd(cmd))
File “C:\OSGeo4W\apps\grass\grass-6.4.4\etc\python\grass\s
cript\task.py”, line 474, in parse_interface
tree = etree.fromstring(get_interface_description(name))
cript\task.py”, line 452, in get_interface_description
“\n\nDetails: %(det)s”) % { ‘cmd’ : cmd, ‘det’ :
decode(cmderr) }
grass.script.core
ScriptError
end
thanks, Roy.
