Hi guys.
I’m trying to install the r.hazard.flood module but I get this error when I run g.extension
(Wed Nov 21 21:56:54 2012)
g.extension.py extension=r.hazard.flood svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
Fetching <r.hazard.flood> from GRASS-Addons SVN (be patient)…
Compiling…
Makefile:5: /usr/lib/grass64/include/Make/Script.make: No
such file or directory
make: *** No rule to make target
`/usr/lib/grass64/include/Make/Script.make’. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
(Wed Nov 21 21:57:00 2012) Command finished (5 sec)
When I look into https://svn.osgeo.org/grass/grass-addons/grass6/raster/r.hazard.flood/, the folder has the following files:
- Makefile
- description.html
- r.hazard.flood.py
I need to run the makefile or I just need to copy the r.hazard.flood.py script into a specific folder? I’m currently using ubuntu 12.10 and installed grass via apt-get with the ubuntugis package.
Thank you in advance!
Andrés Fock Kunstmann
Geólogo - Magíster en Ciencias
