[GRASS-user] problem with r.li.mps
Hi GRASS USER
I tried to reproduce the r.li exemple from the GRASS book and have a problem with r.li.mps, i tried with the 6.4.2svn version and i upgrade to 6.5svn but i still have the same issue.
(i skip the part of the code where forest1996 is build). I don’t know if this matter but i use kubuntu natty. And ask me for more info if necessary.
so forest1996 is my raster map of forest category (only).
r.li.mps --overwrite map=forest1996 conf=movwindow7 output=forest_p_mps7
--------------------------------- output -----------------------------------
*** glibc detected *** r.li.mps: double free or corruption (fasttop): 0x0000000001e17bf0 ***
*** glibc detected *** r.li.mps: double free or corruption (fasttop): 0x0000000001e16a20 ***
*** glibc detected *** r.li.mps: double free or corruption (fasttop): 0x0000000001e17300 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x78a8f)[0x7f6978ffea8f]
*** glibc detected *** r.li.mps: double free or corruption (fasttop): 0x0000000001e178f0 ***
r.li.mps(calculate+0x58e)[0x4017fe]
r.li.mps(meanPatchSize+0x148)[0x402cc8]
/usr/local/grass-6.5.svn/lib/libgrass_rli.so(worker+0x2fa)======= Backtrace: =========
/usr/local/grass-6.5.svn/lib/libgrass_rli.so(calculateIndex+0x99a/lib/x86_64-linux-gnu/libc.so.6(cfree+0x73)[0x7f69790028e3]
r.li.mps(meanPatchSize+0x148)[0x402cc8======= Memory map: ========
/usr/local/grass-6.5.svn/lib/libgrass_rli.so(worker+0x2fa)[0x7f69795a3c3a]
/usr/local/grass-6.5.svn/lib/libgrass_rli.so(calculateIndex+0x99a)[0x7f69795a339a]
r.li.mpsr.li.mps======= Memory map: ========
00400000-00404000 r-xp 00000000 08:01 10106197 /usr/local/grass-6.5.svn/bin/r.li.mps
00603000-00604000 r–p 00003000 08:01 10106197 /usr/local/grass-6.5.svn/bin/r.li.mps
00604000-00605000 rw-p 00004000 08:01 10106197 /usr/local/grass-6.5.svn/bin/r.li.mps
01e05000-01e26000 rw-p 00000000 00:00 0 [heap]
7f6974000000-7f6974021000 rw-p 00000000 00:00 0
7f6974021000-7f6978000000 —p 00000000 00:00 0
7f6978b6c000-7f6978b81000 r-xp 00000000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f6978b81000-7f6978d80000 —p 00015000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f6978d80000-7f6978d81000 r–p 00014000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f6978d81000-7f6978d82000 rw-p 00015000 08:01 1314462 /lib/x86_64-linux-gnu/libgcc_s.so.1
7f6978d82000-7f6978d84000 r-xp 00000000 08:01 1314444 /lib/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff)[0x7f6978fa4eff]
r.li.mps[0x4010c9]
/x86_64-linux-gnu/libdl-2.13.so
7f6978d84000-7f6978f84000 —p 00002000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7f6978f84000-7f6978f85000 r–p 00002000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7f6978f85000-7f6978f86000 rw-p 00003000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7f6978f86000-7f6979110000 r-xp 00000000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7f6979110000-7f697930f000 —p 0018a000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7f697930f000-7f6979313000 r–p 00189000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7f6979313000-7f6979314000 rw-p 0018d000 08:01 1314434 /lib/x86_64-linux-gnu/libc-2.13.so
7f6979314000-7f697931a000 rw-p 00000000 00:00 0
7f697931a000-7f697939e000 r-xp 00000000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7f697939e000-7f697959d000 —p 00084000 08:01 1314471 /li/lib/x86_64-linux-gnu/libc.so.6(+0x78a8f)[0x7f6978ffea8f]
7f697959d000-7f697959e000 r–p 00083000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7f697959e000-7f697959f000 rw-p 00084000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7f697959f000-7f69795a7000 r-xp 00000000 08:01 10106412 /usr/local/grass-6.5.svn/lib/libgrass_rli.6.5.svn.so
7f69795a7000-7f69797a6000 —p 00008000 08:01 10106412 /usr/local/grass-6.5.svn/lib/libgrass_rli.6.5.svn.so
7f69797a6000-7f69797a7000 r–p 00007000 08:01 10106412 /usr/local/grass-6.5.svn/lib/libgrass_rli.6.5.svn.so
7f69797a7000-7f69797a8000 rw-p 00008000 08:01 10106412 /usr/local/grass-6.5.svn/lib/libgrass_rli.6.5.svn.so
7f69797a8000-7f69797bf000 r-xp 00000000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7f69797bf000-7f69799be000 —p 00017000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7f69799be000-7f69799bf000 r–p 00016000 08:01 1314/lib/x86_64-linux-gnu/libc.so.6(cfree+0x73)[0x7f69790028e3]
r.li.mps[0x4010c9]
7f6978d82000-7f6978d84000 r-xp 00000000 08:01 1314444 /lib/x86_64-linux-gnu/libdl-2.13.so
7f697931a000-7f697939e000 r-xp 00000000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so*** glibc detected *** r.li.mps: free(): invalid next size (fast): 0x0000000001e181e0 ***
r.li.mps[0x4010c9]
01e05000-02813000 rw-p 00000000 00:00 0 [heap]
7f697939e000-7f697959d000 —p 00084000 08:01 1314471 /lib/x86_64-linux-gnu/libm-2.13.so
7f69799be000-7f69799bf000 r–p 00016000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7f69799bf000-7f69799c0000 rw-p 00017000 08:01 1314517 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7f69799c0000-7f69799c8000 r-xp 00000000 08:01 10106409 /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
7f69799c8000-7f6979bc7000 —p 00008000 08:01 10106409 /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
7f6979bc7000-7f6979bc8000 r–p 00007000 08:01 10106409 /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
7f6979bc8000-7f6979bc9000 rw-p 00008000 08:01 10106409 /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
7f6979bc9000-7f6979c1c000 r-xp 00000000 08:01 10106373 /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
7f6979c1c000-7f6979e1b000 —p 00053000 08:01 10106373 /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
7f6979e1b000-7f6979e1c000 r–p 00052000 08:01 10106373 /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
7f6979e1c000-7f6979e1e000 rw-p 00053000 08:01 10106373 /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
7f6979e1e000-7f6979e1f000 rw-p 00000000 00:00 0
7f6979e1f000-7f6979e40000 r-xp 00000000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.so
7f697a008000-7f697a00d000 rw-p 00000000 00:00 0
7f697a03d000-7f697a03f000 rw-p 00000000 00:00 0
7f697a03f000-7f697a040000 r–p 00020000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.so
7f697a040000-7f697a042000 rw-p 00021000 08:01 1314421 /lib/x86_64-linux-gnu/ld-2.13.so
7fffc05a0000-7fffc05c1000 rw-p 00000000 00:00 0 [stack]
7fffc05ff000-7fffc0600000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
(attachments)
movwindow7 (84 Bytes)
