[GRASS-user] problem with r.li.mps
ahmadou dicko wrote:
I tried to reproduce the r.li exemple from the GRASS book
and have a problem with r.li.mps, i tried with the 6.4.2svn
version and i upgrade to 6.5svn but i still have the same
issue.
(i skip the part of the code where forest1996 is build).
could you describe the method? is it just an extraction of
category 2 from landcover_1m?
[If it is ok with Markus & Helena perhaps we could add it as the
example on the r.li.mps help page]
I don't know if this matter but i use kubuntu natty. And
ask me for more info if necessary.
so forest1996 is my raster map of forest category (only).
r.li.mps --overwrite map=forest1996 conf=movwindow7 output=forest_p_mps7
*** glibc detected *** r.li.mps: double free or corruption
(fasttop): 0x0000000001e17bf0 ***
r.li.mps(calculate+0x58e)[0x4017fe]
r.li.mps(meanPatchSize+0x148)[0x402cc8]
/usr/local/grass-6.5.svn/lib/libgrass_rli.so(worker+0x2fa)
1314471 /lib/x86_64-linux-gnu/libm-
2.13.so*** glibc detected *** r.li.mps: free(): invalid next
size (fast): 0x0000000001e181e0 ***
Hamish
Hi
Not exactly, is an extraction of the category 5 (forest) from the landclass96 image
r.mapcalc ‘forest1996 = if (landclass96 == 5, 1, null())’
But the behaviour doesn’t change if you choose the category 5 of the landcover_1m
It will be great…
Thank’s for reporting this as a bug
Ahmadou
2011/9/19 Hamish <hamish_b@yahoo.com>
issue.
I don’t know if this matter but i use kubuntu natty. And
Hamish
