[GRASS-user] Problem with r. mapcalc
Dear all
I have some strange behaviour in r.mapcalc that i can not figure out the reason.
I have a Float32 raster with very large pixels values
wget https://www.dropbox.com/s/pxh473rs34wvxuc/basin_lbasin_172_oft_crop.tif?dl=0
min max
241981407232 3266766176256
I want rescale to in such a way that the min is reachin 1 and the maximum value is - min
Therfore
min=241981407231.0
r.mapcalc " output = float( float(input) - $min ) "
and i get
min max output
1 3024784719872
which rather should be
3266766176256 - 241981407231 = 3024784769025
It seems to me that the subtraction is working fine for small numbers but not for larger numbers.
I tried all the combinations of
r.mapcalc " output = float( input - $min ) "
Attached the script.
Did I reach some numerical limitation?
Any suggestions?
Thanks giuseppe
(attachments)
sc39_lbasin_basin_uniq_CompUnit_test.sh (2.46 KB)
Giuseppe Amatulli, Ph.D.
Research scientist at
School of the Environment
Yale University
New Haven, CT, USA - 06511
Tweeter: @BigDataEcology
Teaching: http://spatial-ecology.net
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
Hello Giuseppe,
I am too lazy to calculate binary representation of your numbers, but
your suspicion of insufficient precision of float seems to be spot-on.
If output is set to DCELL, then the result is exactly as you would
expect. Try yourself:
r.mapcalc expression="output=basin - 241981407231.0"
Range of data: min = 1 max = 3024784769025
Māris.
Thanks Maris!!
How can I force the output to be DCELL?
How can I get the “Range of data:” without the scientific number notation?
thanks
Giuseppe
Yale University
On Thu, Feb 25, 2021 at 2:32 PM Giuseppe Amatulli
<giuseppe.amatulli@gmail.com> wrote:
Thanks Maris!!
Please try double() instead of float() in your formula.
How can I get the "Range of data:" without the scientific number notation?
To which command do you refer to?
Markus, output of r.univar and r.info both can have scientific
notation in their range outputs.
Giuseppe, at least on my system r.mapcalc for floating point
expressions (if one of operands is floating point) defaults to double
(stored as DCELL). Still to be safe you can convert one of operands
(e.g. input map with ints) to double with double() as Markus already
pointed out.
Good luck,
Māris.
Thanks to both of you!!
Now I got it! So the
Float32, CFloat32 -3.4E38 3.4E38 range identify the maximum number of characters in the binary format and not in the decimal format - correct?
So even if 3024784769025 fit as a decimal number in -3.4E38 3.4E38 does not fit as binary - correct?
…this one I did not know… I spent a few days on this.
yes r.info gives the scientific format so it will be nice to have also the long decimal number… .to spot this kind of errors.
Giuseppe
Yale University
Sorry, my wrong conclusion
Single-precision floating-point variables are able to represent integers between [-16777216, 16777216]
maybe better to report in the r.out.gdal data type table
Yale University
On Fri, Feb 26, 2021 at 2:20 AM Giuseppe Amatulli
FWIW: We have some info about raster precision and semantics here:
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Raster_management
https://grasswiki.osgeo.org/wiki/GRASS_raster_semantics
(@All) Please expand the Wiki pages as needed.
Wiki updated!!
I hope that users will notice the range-bound of Folat32 to be from -16777216 to 16777216.
Thanks Again
Best
Giuseppe
Yale University
I think an overview table, like https://gitlab.com/-/snippets/2083412, should be part of both the raster introduction text and the manual of r.mapcalc.
Thank you, Nikos
Would you mind adding them and creating a PR, Nikos??
That’d be great :slight_smile:
Thank you, Nikos
grass-user mailing list
grass-user@lists.osgeo.org
Probably also a warning message will be good in the
r.mapcalc
r.out.gdal
when using FCELL (Float32) and overpassing the -16777216 to 16777216.
Indeed, I didn’t know there was such a numerical limit - so I’m wondering how many times I have overpassed :frowning:
Best
Giuseppe
Yale University
Hi Giuseppe,
On Tue, Mar 2, 2021 at 12:20 AM Giuseppe Amatulli
r.mapcalc
r.out.gdal
Indeed, I didn't know there was such a numerical limit - so I'm wondering how many times I have overpassed :frowning:
Please open a ticket with an (ideally based on the North Carolina
sample dataset) example at
https://github.com/OSGeo/grass/issues
(here it gets easily lost)
thanks,
