[GRASS-user] problem with script started form directory differend than home
Hi
in the script, which is started from ~/grass/rzeki/
I have the problem with line
v.db.connect -o map='red_'$k driver=dbf database=~/$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ table='cont_'$k key=cat layer=1
I recive error:
warning:Cannot open database '~////dbf/'
warning:Cannot open database '~////dbf/' by driver 'dbf'
error:Table <cont_lutynia> not exist in database <~////dbf/>
it looks like if script is started from different directory it don't see variables? or something dffernt?
JArek
The '~/' at the front of the path shouldn't be there.
Also, you need quote the argument; the DBF driver performs run-time
substitutions of GRASS variables. Without quoting, the shell will try
to expand them, and they aren't defined. IOW:
  'database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
Note: you need to use single quotes, as the shell will expand
variables inside double quotes.
Glynn Clements pisze:
It was added by me because in first case (without ~/) I thought that the reason is in inappropriate path to table, I forgot to remove it during copying
Yes, that was the reason, thanks!
