[GRASS-user] Problem with spearfish example and creating mapset
Basically I have two problems and would be grateful if you could help.
Problem 1: I have managed to installed and opened the winGRASS GIS manager. But I have problem creating new mapset. I have created a database DB1 and within it a Location call Loc1. When I use the 'Projection Values' button on the GIS manager to create new mapset with Loc1 and DB1, the commandline window run and closed, without any mapset such as PERMANANT or User1 created in Loc1 (Loc1 is empty). How could I properly create a mapset so that I can start a new project?
Problem 2: I have tried to use the example data from Spearfish but there was no *.dm file, *.dmrc file or *.grc file in the spearfish60.zip folder....How could I open and try out the spearfish60 example?
Many thanks in advance
Best Regards
Casey Wong
_________________________________________________________________
MSN Hotmail is evolving – check out the new Windows Live Mail http://ideas.live.com
