[GRASS-user] Problem with the execution of commands.
Hi
I have a problem with Grass Gis (Grass 6.4.3RC2), because when I try to execute the command:
[r.radcov csv_file=cell_list_hataDEM_amc_umts_testTEST.csv dem_map=AlbSRTMdem@PERMANENT clutter_map=AlbClut@PERMANENT out_map=test_hataDEM_amc_umts_albTEST frequency=2125 --o]
in terminal it appears this kind of error:
[reading and checking the radio sector csv table…
Error: Cannot open Radio cell/sector input file]
… can anybody tell me were is the problem of non executing of this command.
thnx
On 25.02.2015 14:57, Dita Elbasani wrote:
HiI have a problem with Grass Gis (Grass 6.4.3RC2), because when I
[reading and checking the radio sector csv table.... Error: Cannot
.... can anybody tell me were is the problem of non executing of this command.
Seems like the csv file is not formatted properly? Check the manual maybe? <http://www-e6.ijs.si/RaPlaT/files/doc/GRASS-RaPlaT_User_Manual_1_0a.pdf&gt;
Nikos
Hi!
Please keep the discussion in the public mailing list. If the attempt to execute a GRASS-relevant module/command from within GRASS, doesn't complain with other errors, then it must be something in the csv file.
I don't have the time to test this. Maybe someone else knows.
Cheers, Nikos
On 25.02.2015 16:26, Dita Elbasani wrote:
first of all thanks a lot for your answer. I tried to see again the
csv file but I don't see any mistake there.Let me show you as an
example how I have proceed:
the file "antennamap.csv", I have created in that way:
| antennaType | frequency | frequencyLower | frequencyUpper | EDT |
MSIfilename | technology |
| DBXLH-6565B-VTM-00DT-0850 | 850 | 824 | 896 | 0 |
DBXLH-6565B-VTM-00DT-0850 | GSM-900 |
| DBXLH-6565B-VTM-00DT-0935 | 935 | 870 | 960 | 0 |
DBXLH-6565B-VTM-00DT-0935 | GSM-900 |
| DBXLH-6565B-VTM-00DT-1785 | 1785 | 1710 | 1880 | 0 |
DBXLH-6565B-VTM-00DT-1785 | GSM-1800 |
| DBXLH-6565B-VTM-00DT-1920 | 1920 | 1850 | 1990 | 0 |
DBXLH-6565B-VTM-00DT-1920 | UMTS-2100 |
| DBXLH-6565B-VTM-00DT-2110 | 2110 | 1920 | 2180 | 0 |
DBXLH-6565B-VTM-00DT-2110 | UMTS-2100 |
the file "cell_list_hataDEM_amc_umts_tir_1.csv", in this way:
| cellName | antennaID | beamDirection | electricalTiltAngle |
mechanicalAntennaTilt | heightAGL | antennaType | positionEast |
positionNorth | power | radius | model | P1 | P2 | P3 | P4 | P5 | P6 |
P7 | P8 | P9 | P10 | P11 |
| UNIVERSITETI-K | 51 | 65 | 6 | 2 | 40 | DBXLH-6565B-VTM6 | 401433 |
4574707 | 18.3 | 10 | hataDEM | 42 | 42 | -12 | 0.1 | | | | | |
| UNIVERSITETI-L | 52 | 270 | 6 | 1 | 40 | DBXLH-6565B-VTM6 | 401433
| UNIVERSITETI-M | 53 | 350 | 6 | 3 | 40 | DBXLH-6565B-VTM6 | 401433
| UNIVERSITETI-N | 54 | 65 | 6 | 2 | 40 | DBXLH-6565B-VTM6 | 401433 |
| UNIVERSITETI-O | 55 | 270 | 6 | 1 | 40 | DBXLH-6565B-VTM6 | 401433
| UNIVERSITETI-P | 56 | 350 | 5 | 3 | 40 | DBXLH-6565B-VTM5 | 401433
| New_TIRANA-K | 61 | 75 | 6 | 0 | 35 | DBXLH-6565B-VTM6 | 400127 |
4575153 | 18.3 | 10 | hataDEM | 42 | 42 | -12 | 0.1 | | | | | |
and the msi files attached (as an example)
thank you again
and I'm waiting forward to your answer
Dita
Nikos
Dear All,
Installed GRASS-7.0.0 on Japanese MS-Windows environment.
Trying to set the change GRASS language settings to English and
I get the following error.
GException
   File "C:\Program Files (x86)\GRASS GIS
7.0.0\gui\wxpython\gui_core\preferences.py", line 178, in
OnSave
self.settings.SaveToFile()
7.0.0\gui\wxpython\core\settings.py", line 1032, in
SaveToFile
'detail' : e })
core.gcmd
GException
Any suggestions for fixing this?
Best
Venka
2015-02-25 15:49 GMT+01:00 Venkatesh Raghavan <raghavan@media.osaka-cu.ac.jp>:
GException
OnSave
SaveToFile
'detail' : e })
core.gcmd
GException
hm, I cannot reproduce this error on Czech Windows (switching from
Czech to English). So probably it could be related to JP environment
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Feb 25, 2015 at 7:57 AM, Dita Elbasani <dita_elbasani@yahoo.com>
wrote:
Hi
command.
Have you double-checked the basic things such as separator in the CSV file
and if you are using the right (full) path to the file?
Vaclav
thnx
grass-user mailing list
grass-user@lists.osgeo.org
