[GRASS-user] Problem with v.class.mIR
I’m trying to use this module for classification of an old aerial photos.
After a segmentation (i.segment and i.segment.stats), I would to use a machine learning approach for the real classification.
I tried with v.class.mIR which use also R.
But there is an error and I don’t know how to solve it:
Durante l’avvio - Warning messages:
1: Setting LC_CTYPE=it_IT.cp1252 failed
2: Setting LC_COLLATE=it_IT.cp1252 failed
3: Setting LC_TIME=it_IT.cp1252 failed
4: Setting LC_MONETARY=it_IT.cp1252 failed
Carico il pacchetto richiesto: caret
Carico il pacchetto richiesto: lattice
Carico il pacchetto richiesto: ggplot2
Error in $<-.data.frame(*tmp*, fd, value = integer(0)) :
replacement has 0 rows, data has 11
Calls: $<- → $<-.data.frame
A part is in italian, I’m sorry.
I’m a beginner in grass and R.
Thanks in advance,
Giuseppe
On 20/11/19 11:55, Giuseppe Cillis wrote:
I'm trying to use this module for classification of an old aerial photos.
But there is an error and I don't know how to solve it:
*/Durante l'avvio - Warning messages:
Error in `$<-.data.frame`(`*tmp*`, fd, value = integer(0)) :
Calls: $<- -> $<-.data.frame/*
A part is in italian, I'm sorry.
I'm a beginner in grass and R.
R messages are often not very explicit, unfortunately.
Could you provide us with the exact command line you use (If you use the GUI, you can get the command line by clicking the 'Copy' button once you've filled out all the parameters, or in the history of the 'Console' in the Layer manager.) and an extract of the attribute data you feed into the module ?
Moritz
Thanks for the answer.
v.class.mlR segments_map=gbbb@PERMANENT training_map=tainning@PERMANENT train_class_column=fd output_class_column=vote output_prob_column=prob folds=5 partitions=10 tunelength=10 weighting_metric=accuracy
and the same error with this command:
v.class.mlR segments_map=gbbb training_map=tainning train_class_column=class weighting_mode=smv,swv,qbwwv -i
The vector used was elaborated with i.segment.stats module.
An extract is here:
cat area perimeter fd
1 958 208 1.555034
2 24 22 1.945217
3 160 80 1.726846
4 2036 242 1.440904
5 25 26 2.024344
6 222 96 1.68966
7 8435 1012 1.530879
cat type Integer (9-0)
fd type double/real (25-9)
For the training area (tainning), I use a simple vector with numerical categories (named “cate”) and there are 11 features (just for a trying). The type is in integer64 (10)
Il giorno mer 20 nov 2019 alle ore 12:18 Moritz Lennert <mlennert@club.worldonline.be> ha scritto:
/Durante l’avvio - Warning messages:
Calls: $<- → $<-.data.frame/
GUI, you can get the command line by clicking the ‘Copy’ button once
you’ve filled out all the parameters, or in the history of the ‘Console’
into the module ?
Moritz
No one can help me?
GC
Il giorno mer 20 nov 2019 alle ore 14:06 Giuseppe Cillis <giucillis@gmail.com> ha scritto:
An extract is here:
1 958 208 1.555034
2 24 22 1.945217
3 160 80 1.726846
4 2036 242 1.440904
5 25 26 2.024344
6 222 96 1.68966
into the module ?
Moritz
Sorry for ignoring you up to now, just to much on the platter right now.
Would it be feasible for you to make the data available, privately if necessary ? The easiest (and lightest) would be just the csv output of v.db.select on the training_map and the segments_maps.
Moritz
On 2/12/19 16:31, Giuseppe Cillis wrote:
No one can help me?
GC
Il giorno mer 20 nov 2019 alle ore 14:06 Giuseppe Cillis <giucillis@gmail.com <mailto:giucillis@gmail.com>> ha scritto:
    Thanks for the answer._
    _
    _v.class.mlR segments_map=gbbb@PERMANENT
    partitions=10 tunelength=10 weighting_metric=accuracy_
    _and the same error with this command:
    _
    _v.class.mlR segments_map=gbbb training_map=tainning
    train_class_column=class weighting_mode=smv,swv,qbwwv -i_
    An extract is here:
    1 958 208 1.555034
    2 24 22 1.945217
    3 160 80 1.726846
    4 2036 242 1.440904
    5 25 26 2.024344
    6 222 96 1.68966
    /cat /type Integer (9-0)
    /fd /type double/real (25-9)
    For the training area (t/ainning/), I use a simple vector with
    numerical categories (named/"cate"/) and there are 11 features (just
    <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>
         > Hi,
         > I'm trying to use this module for classification of an old
        aerial photos.
         > After a segmentation (i.segment and i.segment.stats), I would
        to use a
         > machine learning approach for the real classification.
         > I tried with v.class.mIR which use also R.
         > But there is an error and I don't know how to solve it:
         > */Durante l'avvio - Warning messages:
         > 1: Setting LC_CTYPE=it_IT.cp1252 failed
         > 2: Setting LC_COLLATE=it_IT.cp1252 failed
         > 3: Setting LC_TIME=it_IT.cp1252 failed
         > 4: Setting LC_MONETARY=it_IT.cp1252 failed
         > Carico il pacchetto richiesto: caret
         > Carico il pacchetto richiesto: lattice
         > Carico il pacchetto richiesto: ggplot2
         > Error in `$<-.data.frame`(`*tmp*`, fd, value = integer(0)) :
         > replacement has 0 rows, data has 11
         > Calls: $<- -> $<-.data.frame/*
         > A part is in italian, I'm sorry.
         > I'm a beginner in grass and R.
        use the
        once
        'Console'
        feed
        into the module ?
        Moritz
grass-user mailing list
grass-user@lists.osgeo.org
[Guisseppe sent me the files].
The issue is your training file.
As the manual page states:
"The user provides a set of objects (or segments) to be classified, including all feature variables describing these object, and a set of objects to be used as training data, including the same feature variables as those describing the unknown objects, plus one additional column indicating the class each training falls into. The training data can, but does not have to be, a subset of the set of objects to be classified."
IOW, the training data file has to contain the same feature variables as the data you wish to classify.
Your data is:
$ head -1 segmentation_map.csv
cat,area,perimeter,compact_circle,fd
$ head -1 training_map.csv
cat,id,cate
i.e. you training data only includes the id and the class, but not the variables describing the objects.
The reason this is organised in this manner is that you might have training data which is independent of the data you wish to classify, i.e. the ids of the training data might not be linked to the ids in the object data.
Another issue is that in your command, you do not provide a good name for the column that contains the actual class label in the training data:
v.class.mlR segments_map=gbbb@PERMANENT training_map=tainning@PERMANENT train_class_column=fd [...]
v.class.mlR segments_map=gbbb training_map=tainning train_class_column=class [...]
Your training data does not contain a column 'fd' nor a column 'class'. I suppose that in your data it is the column 'cate'.
Moritz
Moritz
No one can help me?
GC
     _
     _
     An extract is here:
     1 958 208 1.555034
     2 24 22 1.945217
     3 160 80 1.726846
     4 2036 242 1.440904
     5 25 26 2.024344
     6 222 96 1.68966
          > Hi,
         aerial photos.
         to use a
         use the
         once
         'Console'
         feed
         into the module ?
         Moritz
