[GRASS-user] Problem with v.out.dxf
Dear Grass users,
I have been using with success grass 6.2.1-3 on Linux pc039 2.6.20-16-generic. I am experiencing problems exporting GRASS vector files to dxf format (v.out.dxf). I launch the command and the output monitor progress bar freezes at the very beginning. The file name is created in PERMANENT but it contains nothing. Is this a bug or am I doing something wrong? I would really appreciate some help.
Thank you
stefania
Stefania Merlo
Department of Archaeology
University of Cambridge
United Kingdom
06 Jul 2007 11:25:20 +0100, S. Merlo <sm399@cam.ac.uk>:
Dear Grass users,
Can you reproduce this behaviour via command line? E.g. in "Spearfish" location:
v.out.dxf in=roads out=roads.dxf
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
06 Jul 2007 11:49:48 +0100, S. Merlo <sm399@cam.ac.uk>:
Thanks Martin for prompt reply.
What happens when I run the command from the terminal is copied below. No
file is created in the folder.
v.out.dxf input=tindxf806 output=tindxf806_4.dxf
100%
Hm, strange, maybe debug output helps to identify the problem...
g.gisenv set=DEBUG=5
or
v.out.dxf input=tindxf806 output=tindxf806_4.dxf 2>debug.txt
Martin
stefania
On Jul 6 2007, Martin Landa wrote:
>Hi,
>> Dear Grass users,
> location:
>Martin
Stefania Merlo
United Kingdom
Hi. This is the message I get on screen. Sorry, but i do not have the ability of understanding what is going on.
Help appreciated.
stefania
D3/5: off = 4599
D3/5: Vect_read_line()
D3/5: V2_read_line_nat(): line = 126
D3/5: Vect__Read_line_nat: offset = 4599
D3/5: type = 8, do_cats = 1 dead = 0
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4628
D3/5: V2_read_line_nat(): line = 127
D3/5: Vect__Read_line_nat: offset = 4628
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4657
D3/5: V2_read_line_nat(): line = 128
D3/5: Vect__Read_line_nat: offset = 4657
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4686
D3/5: V2_read_line_nat(): line = 129
D3/5: Vect__Read_line_nat: offset = 4686
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4715
D3/5: V2_read_line_nat(): line = 130
D3/5: Vect__Read_line_nat: offset = 4715
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4744
D3/5: V2_read_line_nat(): line = 131
D3/5: Vect__Read_line_nat: offset = 4744
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4773
D3/5: V2_read_line_nat(): line = 132
D3/5: Vect__Read_line_nat: offset = 4773
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4802
D3/5: V2_read_line_nat(): line = 133
D3/5: Vect__Read_line_nat: offset = 4802
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4831
D3/5: V2_read_line_nat(): line = 134
D3/5: Vect__Read_line_nat: offset = 4831
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4860
D3/5: V2_read_line_nat(): line = 135
D3/5: Vect__Read_line_nat: offset = 4860
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4889
D3/5: V2_read_line_nat(): line = 136
D3/5: Vect__Read_line_nat: offset = 4889
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4918
D3/5: V2_read_line_nat(): line = 137
D3/5: Vect__Read_line_nat: offset = 4918
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4947
D3/5: V2_read_line_nat(): line = 138
D3/5: Vect__Read_line_nat: offset = 4947
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4976
D3/5: V2_read_line_nat(): line = 139
D3/5: Vect__Read_line_nat: offset = 4976
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5005
D3/5: V2_read_line_nat(): line = 140
D3/5: Vect__Read_line_nat: offset = 5005
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5034
D3/5: V2_read_line_nat(): line = 141
D3/5: Vect__Read_line_nat: offset = 5034
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5063
D3/5: V2_read_line_nat(): line = 142
D3/5: Vect__Read_line_nat: offset = 5063
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5092
D3/5: V2_read_line_nat(): line = 143
D3/5: Vect__Read_line_nat: offset = 5092
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5121
D3/5: V2_read_line_nat(): line = 144
D3/5: Vect__Read_line_nat: offset = 5121
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5150
D3/5: V2_read_line_nat(): line = 145
D3/5: Vect__Read_line_nat: offset = 5150
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5179
D3/5: V2_read_line_nat(): line = 146
D3/5: Vect__Read_line_nat: offset = 5179
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5208
D3/5: V2_read_line_nat(): line = 147
D3/5: Vect__Read_line_nat: offset = 5208
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5237
D3/5: V2_read_line_nat(): line = 148
D3/5: Vect__Read_line_nat: offset = 5237
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5266
D3/5: V2_read_line_nat(): line = 149
D3/5: Vect__Read_line_nat: offset = 5266
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5295
D3/5: V2_read_line_nat(): line = 150
D3/5: Vect__Read_line_nat: offset = 5295
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5324
D3/5: V2_read_line_nat(): line = 151
D3/5: Vect__Read_line_nat: offset = 5324
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5353
D3/5: V2_read_line_nat(): line = 152
D3/5: Vect__Read_line_nat: offset = 5353
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5382
D3/5: V2_read_line_nat(): line = 153
D3/5: Vect__Read_line_nat: offset = 5382
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5411
D3/5: V2_read_line_nat(): line = 154
D3/5: Vect__Read_line_nat: offset = 5411
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5440
D3/5: V2_read_line_nat(): line = 155
D3/5: Vect__Read_line_nat: offset = 5440
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5469
D3/5: V2_read_line_nat(): line = 156
D3/5: Vect__Read_line_nat: offset = 5469
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5498
D3/5: V2_read_line_nat(): line = 157
D3/5: Vect__Read_line_nat: offset = 5498
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5527
D3/5: V2_read_line_nat(): line = 158
D3/5: Vect__Read_line_nat: offset = 5527
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5556
D3/5: V2_read_line_nat(): line = 159
D3/5: Vect__Read_line_nat: offset = 5556
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5585
D3/5: V2_read_line_nat(): line = 160
D3/5: Vect__Read_line_nat: offset = 5585
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5614
D3/5: V2_read_line_nat(): line = 161
D3/5: Vect__Read_line_nat: offset = 5614
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5643
D3/5: V2_read_line_nat(): line = 162
D3/5: Vect__Read_line_nat: offset = 5643
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5672
D3/5: V2_read_line_nat(): line = 163
D3/5: Vect__Read_line_nat: offset = 5672
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5701
D3/5: V2_read_line_nat(): line = 164
D3/5: Vect__Read_line_nat: offset = 5701
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5730
D3/5: V2_read_line_nat(): line = 165
D3/5: Vect__Read_line_nat: offset = 5730
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5759
D3/5: V2_read_line_nat(): line = 166
D3/5: Vect__Read_line_nat: offset = 5759
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5788
D3/5: V2_read_line_nat(): line = 167
D3/5: Vect__Read_line_nat: offset = 5788
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5817
D3/5: V2_read_line_nat(): line = 168
D3/5: Vect__Read_line_nat: offset = 5817
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5846
D3/5: V2_read_line_nat(): line = 169
D3/5: Vect__Read_line_nat: offset = 5846
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5875
D3/5: V2_read_line_nat(): line = 170
D3/5: Vect__Read_line_nat: offset = 5875
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5904
D3/5: V2_read_line_nat(): line = 171
D3/5: Vect__Read_line_nat: offset = 5904
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5933
D3/5: V2_read_line_nat(): line = 172
D3/5: Vect__Read_line_nat: offset = 5933
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5962
D3/5: V2_read_line_nat(): line = 173
D3/5: Vect__Read_line_nat: offset = 5962
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5991
D3/5: V2_read_line_nat(): line = 174
D3/5: Vect__Read_line_nat: offset = 5991
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6020
D3/5: V2_read_line_nat(): line = 175
D3/5: Vect__Read_line_nat: offset = 6020
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6049
D3/5: V2_read_line_nat(): line = 176
D3/5: Vect__Read_line_nat: offset = 6049
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6078
D3/5: V2_read_line_nat(): line = 177
D3/5: Vect__Read_line_nat: offset = 6078
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6107
D3/5: V2_read_line_nat(): line = 178
D3/5: Vect__Read_line_nat: offset = 6107
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6136
D3/5: V2_read_line_nat(): line = 179
D3/5: Vect__Read_line_nat: offset = 6136
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6165
D3/5: V2_read_line_nat(): line = 180
D3/5: Vect__Read_line_nat: offset = 6165
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6194
D3/5: V2_read_line_nat(): line = 181
D3/5: Vect__Read_line_nat: offset = 6194
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6223
D3/5: V2_read_line_nat(): line = 182
D3/5: Vect__Read_line_nat: offset = 6223
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6252
D3/5: V2_read_line_nat(): line = 183
D3/5: Vect__Read_line_nat: offset = 6252
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6281
D3/5: V2_read_line_nat(): line = 184
D3/5: Vect__Read_line_nat: offset = 6281
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6310
D3/5: V2_read_line_nat(): line = 185
D3/5: Vect__Read_line_nat: offset = 6310
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6339
D3/5: V2_read_line_nat(): line = 186
D3/5: Vect__Read_line_nat: offset = 6339
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6368
D3/5: V2_read_line_nat(): line = 187
D3/5: Vect__Read_line_nat: offset = 6368
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6397
D3/5: V2_read_line_nat(): line = 188
D3/5: Vect__Read_line_nat: offset = 6397
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6426
D3/5: V2_read_line_nat(): line = 189
D3/5: Vect__Read_line_nat: offset = 6426
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6455
D3/5: V2_read_line_nat(): line = 190
D3/5: Vect__Read_line_nat: offset = 6455
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6484
D3/5: V2_read_line_nat(): line = 191
D3/5: Vect__Read_line_nat: offset = 6484
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6513
D3/5: V2_read_line_nat(): line = 192
D3/5: Vect__Read_line_nat: offset = 6513
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6542
D3/5: V2_read_line_nat(): line = 193
D3/5: Vect__Read_line_nat: offset = 6542
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6571
D3/5: V2_read_line_nat(): line = 194
D3/5: Vect__Read_line_nat: offset = 6571
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6600
D3/5: V2_read_line_nat(): line = 195
D3/5: Vect__Read_line_nat: offset = 6600
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6629
100%
D3/5: V2_read_line_nat(): line = 196
D3/5: Vect__Read_line_nat: offset = 6629
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6658
100%
or
Martin
stefania
>Hi,
>> Dear Grass users,
> location:
>Martin
Stefania Merlo
United Kingdom
Stefania Merlo
United Kingdom
Stefania,
this is really whole debug output, anything is not missing? Are you
able to send (me) any testing data?
Martin
06 Jul 2007 15:09:10 +0100, S. Merlo <sm399@cam.ac.uk>:
Help appreciated.
stefania
D3/5: off = 4599
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4628
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4657
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4686
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4715
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4744
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4773
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4802
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4831
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4860
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4889
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4918
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4947
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 4976
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5005
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5034
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5063
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5092
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5121
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5150
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5179
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5208
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5237
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5266
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5295
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5324
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5353
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5382
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5411
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5440
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5469
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5498
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5527
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5556
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5585
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5614
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5643
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5672
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5701
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5730
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5759
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5788
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5817
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5846
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5875
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5904
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5933
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5962
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 5991
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6020
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6049
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6078
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6107
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6136
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6165
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6194
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6223
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6252
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6281
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6310
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6339
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6368
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6397
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6426
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6455
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6484
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6513
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6542
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6571
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6600
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6629
100%
D3/5: n_cats = 1
D3/5: n_points = 1
D3/5: off = 6658
>Hi,
>> 100%
>or
>Martin
>> stefania
>> >Hi,
>> >> Dear Grass users,
>> > location:
>> >Martin
>> Stefania Merlo
>> United Kingdom
Stefania Merlo
United Kingdom
... anyway I din't find anything wrong in the debug output ...
Martin
2007/7/6, Martin Landa <landa.martin@gmail.com>:
Stefania,
Martin
> Help appreciated.
> stefania
> D3/5: off = 4599
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4628
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4657
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4686
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4715
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4744
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4773
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4802
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4831
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4860
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4889
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4918
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4947
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 4976
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5005
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5034
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5063
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5092
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5121
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5150
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5179
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5208
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5237
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5266
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5295
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5324
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5353
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5382
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5411
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5440
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5469
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5498
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5527
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5556
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5585
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5614
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5643
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5672
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5701
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5730
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5759
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5788
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5817
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5846
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5875
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5904
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5933
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5962
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 5991
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6020
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6049
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6078
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6107
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6136
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6165
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6194
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6223
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6252
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6281
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6310
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6339
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6368
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6397
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6426
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6455
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6484
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6513
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6542
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6571
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6600
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6629
> 100%
> D3/5: n_cats = 1
> D3/5: n_points = 1
> D3/5: off = 6658
> >Hi,
> >> 100%
> >or
> >Martin
> >> stefania
> >> >Hi,
> >> >> Dear Grass users,
> >> > location:
> >> >Martin
> >> Stefania Merlo
> >> United Kingdom
> Stefania Merlo
> United Kingdom
