[GRASS-user] problem with v.out.ogr & pgsql
I'm trying to export a polygon from GRASS to postgis and the command I'm
using is like this
v.out.ogr -c input=polygon@mapset type=area dsn=PG:host=localhost
dbname=postgis user=users password=users format=PostgreSQL
but I always get
ERROR 1: AddGeometryColumn failed for layer
polygon@mapset, layer creation has failed.
ERROR: Unable to create OGR layer
The database is spatially enabled and the user has the right permissions
to write in it.
Didn't had much more success with v.out.ogr.pg.py has the error message
is the same.
Any hint?
thanks in advance
-- Giovanni --
On Wed, Mar 31, 2010 at 1:21 AM, Giovanni Manghi
<giovanni.manghi@gmail.com> wrote:
using is like this
but I always get
to write in it.
Does export to SHP file work (v.out.ogr) and upload to PostGIS
(shp2pgsql)? Really all permissions ok?
Sometimes GUI output is not like commandline commands have to be. Maybe its just the missing " ".
v.out.ogr -c input=polygon@mapset type=area dsn="PG:host=localhost"
Hi Markus,
thanks for the reply
it seems all ok.
v.out.ogr works for shapes, and I can upload to postgis with the same
user to the same database with shp2pgsql or with other clients that use
it (qgis).
cheers
-- Giovanni --
using is like this
but I always get
to write in it.
In particular, check permissions on the geometry_columns table. In psql type:
\dp geometry_columns;
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
type:
it is ok,
it has been given a "GRANT ALL"
cheers
-- Giovanni --
I tested from the command line with the " ", and from the wx gui (that
apparently does not add the " ") and the result is the same.
-- Giovanni --
