I have a problem using v.proj. In in the destination location the vector map is incomplete, it seems that the topology is not completely built. In particular, there are missing polygons. The command line:
Building topology for vector map <suolo_paes_ext>…
Registering primitives…
5305 primitives registered
26646 vertices registered
Building areas…
WARNING: Area of size = 0.0 ignored
100%
462 areas built
35 isles built
Attaching islands…
100%
Attaching centroids…
100%
Number of nodes: 4665
Number of primitives: 5305
Number of points: 0
Number of lines: 0
Number of boundaries: 4934
Number of centroids: 371
Number of areas: 462
Number of isles: 35
Number of incorrect boundaries: 4116
Number of centroids outside area: 224
Number of duplicate centroids: 12
Number of areas without centroid: 327
I’m using Debian, and tried both with grass6.4 debian package and grass6.5 svn
I also tried to use v.build after that, without results.
On Sat, Dec 4, 2010 at 8:18 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Hi List,
Building topology for vector map <suolo_paes_ext>...
Registering primitives...
Building areas...
You are reprojecting from UTM_32_ED50 into ...?
In any case, you may need to clean up the topology *before* running v.proj.
Perhaps the original map isn't clean.
and imported the reprojected map with v.in.ogr. All polygons are reprojected now.
But I noticed that using v.proj the map was reprojected with an important error .I have another map of the same area, when I try to overlay them they are in two different places, very far apart. But when I overlay the map reprojected with ogr, everythings looks OK.
Couldn’t it be a bug of v.proj? Has anyone had a similar problem using v.proj?
Hi List,
Building areas…
You are reprojecting from UTM_32_ED50 into …?
In any case, you may need to clean up the topology before running v.proj.
Perhaps the original map isn’t clean.
